possible solution
Old Mar 4, 2003 | 02:23 PM
dchi_t's Avatar
Default possible solution
my pops has a 90 accord auto, and it had the same problem, lemme describe his prob, his car's idle would surge when its warming up i.e morning b4 work...i fixed the problem by swapping a what cha ma call it? ...uhh..nutz..i forgot whats it called, but i'll describe it to u, its a mechanical sensor in front of the firewall. it has kinda of a bronze top w/ 2 philips screw on it, two outlets are on the bottom where coolant flows through, if u unscrew the top there will be something like a ball which u can press down and u'll hear air be sukked in. thats what the problem was w/ pop's car, dont start the engine, take that mechanical sensor out, clean it out, cuz pop's sensor had coolant buildup clogging the sensor. thats it, that might be the solution..good luck
garnet
Jun 28, 2014 05:20 PM
goshred025
Nov 4, 2005 04:15 PM
chinaski
Jul 4, 2005 10:49 PM
civic1990si
May 13, 2004 09:15 PM
boosted_zc
Mar 12, 2003 04:11 AM
