Replace temperatue sensor?
Old Nov 2, 2005 | 09:52 PM
goshred025's Avatar
Default Replace temperatue sensor?
does anyone know where i could find a step by step guide to replacing the sensor? also how hard would it be?
Old Nov 3, 2005 | 04:29 PM
blkb18's Avatar
Default Re: Replace temperatue sensor? (goshred025)
what kind of car and why are you replacing it?
Old Nov 3, 2005 | 08:55 PM
goshred025's Avatar
im replacing a 95 Rs b18b1 temperature sensor. the problem with my car is that my temperature guage allways read cold. it dont move as if the car was off. from the mechanic at acura he told me that was the problem.. racebred h, your sensor might also be going out? before it went my car ran cool never reached the middle while moving and when in trafic it it will get a bit hotter. then eventually it just stoped. but i had only a day to decide weither its a big job or somthing i could do. and i rather just have them do it.. thanks anyways though guys
Old Nov 3, 2005 | 09:59 PM
volcom40street's Avatar
All you do is unscrew the old one and screw the new one on.
It will take you, lets see, 1 minute or so to complete the job.
Remember though, if you replace your sensor (for higher or lower temp.) make sure it coensides with your thermostate. If it deosn't it defeats the purpose of the other.
Old Nov 4, 2005 | 03:03 PM
blkb18's Avatar
Default Re: Replace temperatue sensor? (Racebred H)
sounds like stuck open t-stat.
Old Nov 4, 2005 | 04:15 PM
mattcivic's Avatar
Default Re: Replace temperatue sensor? (blkb18)
is it throwing the temp sensor code? if not ya its sounds like an open thermostat get an oem replacement screw those garbage aftermarket "cooler" ones i dont like them. im one to talk i have one in my car but i do havea brand new oem one sitting there just waiting to go in
951parts
Aug 9, 2012 11:43 AM
skateboard_ej8
Apr 5, 2011 09:21 AM
yusoslo
Dec 31, 2004 06:34 PM
prostreetonline
Jul 10, 2004 12:21 PM
civic1990si
May 13, 2004 09:15 PM
