NEED HELP ASAP!!!!!! b16a wont start.....
Old Mar 4, 2003 | 02:16 PM
driftt's Avatar
Default NEED HELP ASAP!!!!!! b16a wont start.....
ok i swapped out my engine in my car a 89 crx si with a b16a the engine came out of a running car so i know its good, it came out of a 91 hf, i belive the problem is in the wiring, im using the harness that was on the motor, the wire colors are different colors in the round plug up in the driverside rear of the engine bay, i belive this is the wiring for the injectors, the car act like its not getting fuel, when i try to start it the ecu throws code 15 (ignitor) but i know im making spark, also i have no idea where any of the vacuume hoses hook back up i wouldnt think that would cause it to not start, im pretty sure its electircal, tia joe....
Old Mar 4, 2003 | 03:54 PM
Torino91LS's Avatar
Default Re: NEED HELP ASAP!!!!!! b16a wont start..... (driftt)
Check the ground on the thermostat housing. Number one Swap Killer.
Old Mar 4, 2003 | 05:02 PM
chad174's Avatar
Default Re: NEED HELP ASAP!!!!!! b16a wont start..... (kincaidcrxsi)
you're supposed to use your stock SI harness, then wire up VTEC, knock sensor and anything else. your b16a harness WILL NOT work in your SI. good luck.
Old Mar 4, 2003 | 05:20 PM
swaplighter's Avatar
Default Re: NEED HELP ASAP!!!!!! b16a wont start..... (chad174)
if it came out a 91 hf...is the harness on it from a 91 hf or the og harness? i had this stupid problem 2 days ago.. use your og engine harness that came with your car and wire all extras independently...
BTW::like kincaidcrxsi said..check all your grounds! very crucial to the whole electrical system. make sure they are clean.
[Modified by swaplighter, 2:22 AM 3/5/2003]
Old Mar 4, 2003 | 05:35 PM
PhatHardy's Avatar
Default Re: NEED HELP ASAP!!!!!! b16a wont start..... (swaplighter)
what year is the car that the engine is in now?
Old Mar 4, 2003 | 05:44 PM
driftt's Avatar
Default Re: NEED HELP ASAP!!!!!! b16a wont start..... (PhatHardy)
ehhh never mind got it going, i swapped out the harness it had to the one from the si's original engine, problem solved, even though it was a pain in the ***
08yfzrider
Aug 4, 2010 06:06 AM
Sleepingcrx
May 3, 2006 12:25 PM
LD_EGSICK
20
Feb 4, 2003 07:47 PM
chirp3rd
Feb 6, 2002 12:10 PM
