Friend just got her B16A got some questions???
Ok listen we just got a B16a 1st gen. for a 91 hf and the harness on the engine is kinda of cut, i wanna know if the HF stock harness can be used on the motor or what modifications that are needed. Also the distributor cap is broken which cap do we have to buy for this motor????
I did a search and it really didnt help me so some1 please help me out?????
Re: Friend just got her B16A got some questions??? (chirp3rd)
HF harness requires alot of changing due to the dual port fuel injection....i would reccomend an Si wire harness
for the cap you're gonna use one off of a 91 Integ
Re: Friend just got her B16A got some questions??? ([626]JDM-b16a-EF9)
If her HF is MPFI then you can use it, you just need to add VTEC like in an Si harness, and remove a couple extra pins.
Re: Friend just got her B16A got some questions??? (CRX-RX)
Re: Friend just got her B16A got some questions??? (Brandon Chun)
or goto http://www.hasport.com , they have a good section on wiring.
ITSTOCK
11-15-2003 03:51 PM
