Motor Mount installation
Old Mar 4, 2003 | 02:11 PM
Kato7997's Avatar
Default Motor Mount installation
How hard is it to remove and install the rear motor mount?
Old Mar 4, 2003 | 02:18 PM
JoshDM's Avatar
Default Re: Motor Mount installation (Kato7997)
in the ***!
Old Mar 4, 2003 | 02:55 PM
Timmayeg's Avatar
New User
Default Re: Motor Mount installation (JoshDM)
its not bad if the motor is out, if the motor is still in have fun is all i have to say!!
the front bolts are easy, the rear one is a bit tricky, i used a 14mm end wrench and go under the mount itself to get to the rear bolt, or a wobly and extension may work
Old Mar 4, 2003 | 03:26 PM
Flexmyrex's Avatar
Default Re: Motor Mount installation (Timmay)
mine came loose , it was a pain in the *** to put it back with the motor and bracket there.
w out motor easy
Old Mar 4, 2003 | 06:03 PM
goforbroke's Avatar
MEAT PATTY
Default Re: Motor Mount installation (flexmyREX)
Don't worry dude I have to replace mine as well my rear polyurane bushing is busted. I have to contact hasport just been to lazy to give them a call, hopefully it will go smoothly me and you. I don't think it should be that bad though.
218luder
May 23, 2008 02:25 PM
powerdbygarrett
Sep 17, 2007 12:08 PM
Draggin99Si
Jul 27, 2006 06:52 PM
pinecone
11
Mar 25, 2006 02:04 PM
Black R
Jan 31, 2004 07:34 AM
