Full-race turbo kit
This is the kit i am likely to buy...anyone have one or know of anyone who has one please tell me how u like it. here is the list of items included in kit...
Full Race Equal Length Manifold
Full Race "Back Door" Intercooler
Full Race Downpipe
Garrett T3/60-1 Turbo or Garrett T4/T04E 60 Trim Turbo
Tial 40mm Wategate
Greddy Type R Blow Off Valve
Aluminium Intercooler Piping
Full Race Oil Line Kit
Silicon Couplers / Hose Clamps
which turbo would you recomend...i hav a b16a that is going to be sleeved and bored with 9:1 comp. running around 20psi. see it at full-race.com and go to products...its looks like a very well put together kit in my opinion so im gonna give it a try
[Modified by ShowSi2, 9:22 PM 3/4/2003]
Full Race Downpipe
Tial 40mm Wategate
Excellent kit...
Probubly the best you can buy I'm sure.
What are your plans for the car? This will help determine which one for you to use.
BTW, it's T3/TO4E
BTW, it's T3/TO4E
im gonna send my motor to cali to get forged pistons and rods gonna have it bored out to 1.8 and sleeved running 9:1 comp. Gonna change the intake minifold and throttle body out to what im not sure (any suggestions). Only doin little head work, titanium springs and retainers so i can rev higher. Im gonna run 18-20 psi at the track and around 12 daily
we have some very interesting turbos coming out under our own name. They will have far superior center sections to the current crop of Garret GT turbos, are designed to last 1 million miles and the bushing center sections feel like garret ball bearing units. There wont be any garret components in our turbos.
precision is still a the best garret components based turbo, however
what setup are you running? autoEXturbo
Motor
B18C1
Sleeved 84.5mm, arias pistons, eagle rods
Stock gsr head
Turbo
Precision T4 60-1
Inline Pro T4 manifold
Tial 40mm wastegate
Tial bov
3"dp
greddy type 24 intercooler
Fuel
fmu 12:1
440's
255lph pump
safc
nothing at all magical, but we finished the first turbos, and are awaiting the final products. These will be a 700hp capable t3t4 that spools like a much smaller turbo.
autoEXturbo what compression ratio are you running and what is your car gutted/full interior? Do you know how much it weighs
[Modified by F-RTurboCivic, 1:48 AM 3/5/2003]
Large turbos that spool quickly will choke your engine. Do NOT put one of these turbos on your engine. They may spool quick, but they rob power in the form of back pressure. Putting on a smaller turbine to get better spool times is suicide.
its not a small exhaust side, its larger than either the wheels on the precision and the turbonetics stage 5 wheel.
i know about wheelsize matching, thanks for the concern tho.
edit:
93LSivic, if you need someone to techically explain why a smaller turbo chokes your engine, then you are in no position to be flaming
[Modified by UberTeg, 3:14 AM 3/5/2003]
Smarter than you
the VW guys have a problem w/ this. When they first started running T3/T4's on the 20v motors that are set up for great low end they would spool up so quick that the compressor would surge. [Modified by DIRep, 9:06 PM 3/4/2003]
