b series into 5th gen civic mount kit needed?
Old Mar 4, 2003 | 09:46 AM
spun Vtec's Avatar
Default b series into 5th gen civic mount kit needed?
wondering if mount kit is needed for a b series swap into 5th gen
thanks
-larry
Old Mar 4, 2003 | 09:51 AM
splitime's Avatar
Default Re: b series into 5th gen civic mount kit needed? (4gsicivichatch)
Someone will have to back me up on this, but i believe you can just use all existing mounts. No kit necessary. Wait for more feedback though, as I'm not 100%
Old Mar 4, 2003 | 09:53 AM
White Lightnin's Avatar
Default Re: b series into 5th gen civic mount kit needed? (splitime)
Bolts in just fine.
Old Mar 4, 2003 | 09:54 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: b series into 5th gen civic mount kit needed? (White Lightnin)
us the b series mounts that come with the engine...off of the JDM Civic, Teg, or whatever.
Old Mar 4, 2003 | 09:56 AM
IS3Fifty's Avatar
Default Re: b series into 5th gen civic mount kit needed? (Emerica)
use the stock mounts that came on the car, you can use the mounts that came with the motor also.
Old Mar 4, 2003 | 09:58 AM
smnowell's Avatar
Default Re: b series into 5th gen civic mount kit needed? (purek9hybrid)
The mounts that came on the car (aside from the rear mount that is bolted to the crossmember) will NOT work. You need to use the B-series mounts that hopefully came with your motor. If you don't have mounts with your motor, try a junk yard for some mounts or check around online for someone selling them. Also, if you want drag mounts, check out http://www.hasport.com they make mounts that are just bolt in mounts to replace existing b-series mounts, but they are much stiffer
Old Mar 4, 2003 | 09:59 AM
vtecvoodoo's Avatar
Future Texas Boy
Default Re: b series into 5th gen civic mount kit needed? (b16a ferio)
I used the HASport mounts as well. Nothing bling blings liek billet
Old Mar 4, 2003 | 03:30 PM
smiko0124's Avatar
Mounts should come with the engine.. just use those. They came with my b16a swap that I dropped into my 95 dx coupe.... get a short shifter too... HUGE difference and I love mine
eg_21
Jun 8, 2009 07:54 PM
JDM 93 EJ1
Nov 16, 2004 03:15 PM
ForceFed Coupe
Dec 13, 2003 04:19 PM
