b-series swap in a 96 hx
Old Mar 4, 2003 | 06:04 AM
The Jamaican's Avatar
Default b-series swap in a 96 hx
Have any one did this swap and if so did you have to change your wiring harness if not what was done about the wiring. (already did seach) It's a ObdII b16 in a 96 Hx
[Modified by The Jamaican, 3:06 PM 3/4/2003]
Old Mar 4, 2003 | 06:07 AM
eg6ajk's Avatar
Default Re: b-series swap in a 96 hx (The Jamaican)
it all depends on the type of the motor generation/ecu you get. it can be from just simple bolt in affair to fabrication (if you want the first gen B16A in there with cable tranny.)
be more specific on parts you're thinking of using
muahhaha
24
Aug 21, 2011 07:19 PM
Blanket Jackson
May 25, 2005 06:18 AM
NEca18dets13
Mar 16, 2005 07:04 PM
deesracer
May 6, 2004 10:56 AM
