Y8 intake mani install, but i have one problem *HELP*..... *pics*
Ok, i took out the A6 intake manifold and compare it side by side with my manual version y8 intake manifold. Well, i noticed that my A6 manifol had this metal sensor. What should i do with this thing???? Here are some pics what i'm talking about.
Here is the d16a6 intake mani, that is the sensor location what i'm talking about
Here is the metal thing that was attach to the a6 mani.. What is this thing hmm?
Here is my progress so far.
So what do i have to do with the metal sensor thing? The d16y8 mani doesn't have one. I need help!
From: the asshole of america..., upstate new york, USA
where did you mount your IAT sensor?
I see, and i heard that thing too, but we need to get more feedback about this. Since, you are doing this swap too. For the IAT sensor, i would tap under my intake tube. I talked to another h-t member who got the same set-up and what he did is he tapped under he's intake tube. Here is the pic. He said no problem so far and it's not throwing any codes.
yeah, i am just going on what others have said so far. but there really isnt any place to mount that fast idle, so i sure as hell hope it doesn't need it. thanks for the pic of the IAT. once i figure out what cam i want to get i will finally get started on the swap.
are you using the Y8 TB? it looked like a pain in the *** to extend the wires from the MAP. i got a 90 B18A TB (58mm vs 56mm Y8). its set up the same as the A6 TB with the vacuum line to the MAP and all the charoal canister crap too.
I got the same TB as your lol, and yes the map and vacuum line are the same. I have to get some good wires to extend my IAT sensors too.
ok, i plan on using this manifold also. i've never heard of having to 'tap' the IAT sensor in??? What exactly do you mean by tap and what exactly is the IAT sensor??? I have a manual IM and my car is an 89 crx si manual. do i still need to do this IAt thing?
.. you dont need wire to extend it.. just unwrap the loom and pull out the wire and run it back to the air filter housing. a little time consuming but pretty easy. as far as the fast idle solenoid, i left mine plugged in but just zip tied it to some random bracket in the engine bay.
[Modified by d357r0y, 6:48 PM 3/4/2003]
LilCivic04
Jul 23, 2006 10:47 PM
MrTodd
Aug 1, 2002 10:07 PM
