2.5" collector with a 2 1/4" test pipe
Old Mar 3, 2003 | 10:26 PM
ophdehEEzY
Guest
Posts: n/a
Default 2.5" collector with a 2 1/4" test pipe
how would a dc header flow with a modified 2.5" collector and a 2 1/4" test pipe and 2 1/4" piping? would it bottleneck where the header meets up with the test pipe? how big is the dc 4-2-1 collector? would it be better to have a 2 1/4" collector? tia!
edit: how much would a muffler shop typically charge to modify the collector?
peace!
[Modified by ophdeheezy, 11:27 PM 3/3/2003]
Old Mar 3, 2003 | 11:30 PM
Mike95lude's Avatar
Default Re: 2.5" collector with a 2 1/4" test pipe (ophdeheezy)
It wouldn't be optimal. I'd get a 2.5'' test pipe or cat made.
Old Mar 4, 2003 | 07:26 AM
Tru_Playah's Avatar
The OD of the DC collector is 2.25"
Old Mar 4, 2003 | 07:34 AM
SMSP's Avatar
The DC collector is 2" OD. If you are going to run the 2-1/4" test pipe and cat pipe just mod the header with a 2-1/4" collector.
Old Mar 4, 2003 | 08:04 AM
papa_smurf's Avatar
Default Re: 2.5" collector with a 2 1/4" test pipe (SMSP)
how exactly are you gonna mod a dc collector to 2.5"?
Old Mar 4, 2003 | 08:09 AM
2point6's Avatar
Default Re: 2.5" collector with a 2 1/4" test pipe (papa_smurf)
I did this mod and it worked really well. To do this you need to cut the last Merge collector (on the B pipe) back to about its widest point and weld on a 2 12" pipe and flex. SMSP has a lot more experience with headers so I might suggest you take his suggestion of only going 2 1/4" piping off of the collector. 2 1/2" worked killer for me, but He has more Knowledge.
Old Mar 4, 2003 | 10:39 AM
Tru_Playah's Avatar
hmmmm....... I have an email from a DC sport tech stating that the OD of their collector is 2.25"
edit: that was in response to my inquire about the 93-96 Vtec prelude header
[Modified by Tru_Playah, 7:43 PM 3/4/2003]
Old Mar 4, 2003 | 12:50 PM
2point6's Avatar
Default Re: 2.5" collector with a 2 1/4" test pipe (Tru_Playah)
The DC Header I have was measured at 1.9" ID. 93-96 stainless VTEC header.
Old Mar 4, 2003 | 01:44 PM
sharkcohen's Avatar
Yes.
DpQInteg
May 15, 2006 12:55 PM
Phatch99
Aug 17, 2004 02:19 PM
pinota
Oct 28, 2002 11:00 AM
