Where do the ground wires go!!!????
Old Mar 3, 2003 | 08:26 PM
dingusjt's Avatar
Default Where do the ground wires go!!!????
Alright i need to know where ground wires come fron on the engine...so far i know one comes from the valve cover, tranny, and really thats all i can remember. Please someone reply and tell me where they come from. thanks.
Old Mar 3, 2003 | 08:37 PM
PhatOptimo's Avatar
Default Re: Where do the ground wires go!!!???? (dingusjt)
There are 3 ground around the engine. One is at the thermostat housing. The wires that are grounded there come off the engine harness. Then your battery is grounded to the tranny and the valve cover is grounded to the front support member.
Old Mar 3, 2003 | 09:20 PM
Vtecless212's Avatar
Default Re: Where do the ground wires go!!!???? (Phat_Optimo)
i wouldn't ground your valve cover to the chassis tho you'll get a better ground underneath the valve cover on the right side theres a hole for i think a 12 mm head bolt i would ground it there. also make sure you keep your grounds VERY clean i had horrible elec. problems because of dirty grounds
[Modified by jdmturboef, 6:21 AM 3/4/2003]
Old Mar 3, 2003 | 10:08 PM
thaiphob's Avatar
Nikon!!!
acually, it battery, chasis, then tranny.
Old Mar 3, 2003 | 10:40 PM
RCautoworks's Avatar
Default Re: Where do the ground wires go!!!???? (jdmturboef)
Actually your not suppose to use that spot. Your suppose to use the spot on top of the valve cover. Like in the picture below.
[Modified by 90blackcrx, 1:42 AM 3/4/2003]
Old Mar 3, 2003 | 10:45 PM
PhatHardy's Avatar
Default Re: Where do the ground wires go!!!???? (90blackcrx)
i believe he was talking about on the head, but i'm not sure, does it really matter tho, i mean as long as you just ground the head?? And another thing what's the deal with hypergrounds when you get them how many of them are there? Couldn'ty ou just make your own with some speaker power wires??
Old Mar 3, 2003 | 11:04 PM
Default Re: Where do the ground wires go!!!???? (PhatHardy)
There was a post awhile back saying why it was suppose to be grounded there, anyways yeah you could make your own with speaker wire.
[Modified by 90blackcrx, 2:11 AM 3/4/2003]
Old Mar 4, 2003 | 09:38 AM
efvader's Avatar
So jdmturboef it was a bad ground that you had. i read your post a while back and I am having that problem with the car still running too.. Which grounds should I check first? It may be my ignition switch too b/c I haven't checked that either. Later.
Old Mar 4, 2003 | 09:42 AM
martini's Avatar
yeah, I think he is talking about the threaded hole that is just below the "proper" spot in your picture..on the head, not the valve cover..
Old Mar 4, 2003 | 10:16 AM
Hcivic88's Avatar
thats what I did, I didnt really think it made any difference, but thats not the reason i did it. the stock ones were all corroded, the insulation was gone on them and one of them was soldered together. thats what u get for getting a used car.
heres the ones i made
Old Mar 4, 2003 | 10:36 AM
PhatOptimo's Avatar
Default Re: Where do the ground wires go!!!???? (thaiphob)
I am wondeing where on the chassis the neg battery cable goes? I have mine setup the way I described and have not had any problems. Just wondering if i am wiring it wrong?
[Modified by Phat_Optimo, 1:37 PM 3/4/2003]
Old Mar 4, 2003 | 12:27 PM
Vinceg99's Avatar
OK with the ground that comes off the negative post it is one solid cable but it has a place where the insulation has been removed and there is a place where a bolt goes through it to the chassis then it continues on to the tranny. I will try to get a pic the manual I have handy doesnt show it completely so I will either take a pic or find it in one of my other manuals.
Old Mar 4, 2003 | 07:42 PM
PhatOptimo's Avatar
Default Re: Where do the ground wires go!!!???? (Vinceg99)
Cool man I would like too see that.
Old Mar 4, 2003 | 07:44 PM
Hcivic88's Avatar
the negative cable goes from the negative post, to just under the battery where it bolts to the chassis, then to the tranny bracket. I'll look to see if i have a pic on my harddrive
Old Mar 5, 2003 | 07:44 PM
Default Re: Where do the ground wires go!!!???? (Hcivic88)
i was talking about the threaded hole under the valve cover on the actual head. otherwise your grounding it to a valve cover with a RUBBER gasket. but as far as grounds go i did one from the battery with 4 gause wire and gold plated conncetors to the frame rail. first clean around the hole in the frame rail to the metal then bolt it and silicone over it. then ran the ground on the tranny the same way to a different hole on the frame rail, it's better not to have 2 on 1. i did the 1 from the motor the same way and have never had a problem since.
Old Mar 5, 2003 | 09:07 PM
Yeah you ground it to the rubber groment, even though there is a rubber groment, the long stud is there which will ground the hole engine.
Old Mar 5, 2003 | 09:16 PM
MidoriEK4's Avatar
on my car i have the neg going to chasis. then the trans going to chasis. last the valve cover going to the front part of the car. heres what i got.
Old Mar 5, 2003 | 09:20 PM
shorti's Avatar
Default Re: Where do the ground wires go!!!???? (NA CRX Si)
http://www.crx-tuner.com/various/battery1.jpg
http://www.crx-tuner.com/various/battery2.jpg
what kind of battery is that???
i bet that thing couldn't crank under freezing temps
Old Mar 5, 2003 | 09:23 PM
MidoriEK4's Avatar
Default Re: Where do the ground wires go!!!???? (shorti)
cranks fine. and its like 25 degrees.
Old Mar 5, 2003 | 09:24 PM
MidoriEK4's Avatar
oh yeah its a type one racing battery.
Old Mar 6, 2003 | 09:03 PM
PhatOptimo's Avatar
Good pics. I have decided to leave it the way it is seeing there are no problems.
Thanks guys
gabrielsousa
May 21, 2014 08:21 AM
ezcape
May 10, 2011 10:52 PM
yeedub
Dec 10, 2006 12:53 PM
hatch96y7
Aug 16, 2006 05:19 PM
steve_s
Feb 21, 2003 08:59 PM
