Ingalls camber kit instructions and info for future questions
k this is a reference topic and purpose its for future search on how to install camber kits, how much are they, and bla bla bla.....
thanxs to a fellow HT member i found out that http://www.iapdirect.com has the Ingalls Xtreme camber kit # 35730 that adjusts from 1.1/4-3 deg for 130 shipped to my door for both sides....great price considering my local shop wanted 200 +tax, and other places charge u 89 for one side...
anyways i got them today (ordered them thurs)since i had my tires waiting for the kit
and after go for a aligment....
well i went to my friends garage and started the saga...
at the same time i went to home depot and got some washers....i installed 2 in ea bolt of the rear to adjust camber.. i only used 2 since i dont knonw how much they can adjust and i was going to wait for aligment 4 that..... after that i went to the front..... i took the old bushings off with no problems.... went i went to put the ingalls on the A arms i got a problem.... this
the Ingalls bushing its about 1mm or 2mm longer than the stock bushing.. so i had to pry apart a lil that place where the bushing goes in order to make it fit.
after taking care of that, the kit went in with no problems...
time to lower the car.... when i lowered it.. the A arm was to positive and it was hittin the inner side of the fender.... uh-oh.... now i cant put that mush camber adjustment.... well anyways i keep adjusting it lil by lil until i lowered the car and it went good into the fender grove for the arm...... same deal for the other side.... now. since i got 205/50/15's i had to raise my back about 1/4 in bc it was rubbing my tires...
after taking care of the wheel gap.. i gotta say ill wait until tomorrow that the aligment its done to see the full effect of the kit and traction....
well here are some of the final shots jejejeje
sorry about the pics size... i didnt feel like compressin them....
hope this helps for the future... since the search didnt do a lot for me about 2 weeks ago..... now hopefully it will
[Modified by USDM 4G VTEC, 9:31 AM 3/4/2003]
and after go for a aligment....well i went to my friends garage and started the saga...
the Ingalls bushing its about 1mm or 2mm longer than the stock bushing.. so i had to pry apart a lil that place where the bushing goes in order to make it fit.after taking care of that, the kit went in with no problems...
after taking care of the wheel gap.. i gotta say ill wait until tomorrow that the aligment its done to see the full effect of the kit and traction....well here are some of the final shots jejejeje
you can get them for 115 shipped from http://www.importhorizon.com
When you say "both sides" are included, does that mean front & back for each side?
usually they sell by "pairs"
that confuses people since ea side on the front actually uses a pair
means u get 4 bushings.... 2 for ea side of the front
itsJDMyo
13
Jan 7, 2005 10:40 AM
loki2323
Sep 12, 2002 08:52 AM
