AutoX rules - Wheels
or SM2.
stock class rules for wheels - same diameter and width as stock, +/- 1/4" (6.25mm) in offset (spacers ok).
If 15" wheels were an option, then thats ok as long as the width is the same.
SNIP
Del Sol VTECs had 15s standard. I believe you could get 15s as a factory option ont eh others as well.
Dan
Ah, but is the Del Sol VTEC in the same class as the D-series Del Sol? Anybody know?
Incroect all VTEC Del sol came with the same 14 inch rims that the Si's did.
just to point out, your would not be in STS. The del sol does not have back seets right? thus can't run in STS. STS is for 4 person cars.
NM, he said SP, nnot STS /bonk me on the head
[Modified by 57STS, 11:44 AM 3/4/2003]
VTEC del Sols came with 14x6 wheels, while Si del Sols came with 14x5.5 wheels.
Almost correct. VTEC del Sols came with 14x6 wheels, while Si del Sols came with 14x5.5 wheels.
DOHC VTEC del Sols only came with 14x5.5's throughout their entire model run.
Almost correct.
FrostyDC4
20
Jun 6, 2002 03:00 PM
IVANITR
May 20, 2002 08:57 PM
