Any of you guys heard of Split Second FTC1??? SDS ?????
Old Mar 3, 2003 | 05:16 PM
evoeone's Avatar
Default Any of you guys heard of Split Second FTC1??? SDS ?????
like it says, the split second is a piggyback that does fueling/timing, and even has a 2.5 bar MAP for cars like mine that have crappy MAF's (i never understood why a MAP is used on the hondas/ac's)
the split second is like $500 and would work with my ecu and i could keep my drive by cable
SDS ( http://www.sdsefi.com ) is a full stand alone, lotta people use it on VW's, so if i do go stand alone, this will probably be it. even though i would have to convert to drive by cable (which is better)
what do you guys think? the sds is about $1200 with the MAP, coil packs, harness , ecu, everything.
basically seeing what the honda/acura crowd thinks of these systems, i wish hondata had a vwdata
any info would be nice, thanks
Old Mar 3, 2003 | 05:45 PM
rOby's Avatar
Default Re: Any of you guys heard of Split Second FTC1??? SDS ????? (evoeone)
there was one member that used it in his allmotor h22 civic...i dunno his name though..sorry
Old Mar 3, 2003 | 05:52 PM
evoeone's Avatar
Default Re: Any of you guys heard of Split Second FTC1??? SDS ????? (rOby)
yeah, it was a white civic bubble, h22 right? it was on the front page of sdsefi.com, his **** looked really really tight
Old Mar 3, 2003 | 06:08 PM
HybridCoupe's Avatar
Hey, just to let you know im selling my sds for 850....Has everything including b-series pulley with magnets already mounted....Has a pretty decsent tune in it also..
on a stock ls/vtec motor on pump gas i put 292hrs 245 ft lbs..
This is my boys screen name...
[Modified by HybridCoupe, 7:08 PM 3/3/2003]
Old Mar 3, 2003 | 06:25 PM
evoeone's Avatar
Default Re: Any of you guys heard of Split Second FTC1??? SDS ????? (HybridCoupe)
which SDS is it? i want the emf4, is everything that SDS includes in their product description included? give me some info on it, IM me its easier..was that your hatch? and i wish i could use your b -series magnets, but as you can see in my sig,,,i have a 2.0 vw
weejoeturbo
Engine Management and Tuning
Jan 5, 2014 09:05 PM
adam00
Jan 26, 2009 09:19 PM
MEME_ARAVELA
Jul 1, 2008 12:01 PM
zbower7
Jun 21, 2004 08:42 PM
