Any of you guys heard of Split Second FTC1??? SDS ?????
like it says, the split second is a piggyback that does fueling/timing, and even has a 2.5 bar MAP for cars like mine that have crappy MAF's (i never understood why a MAP is used on the hondas/ac's)
the split second is like $500 and would work with my ecu and i could keep my drive by cable
SDS ( http://www.sdsefi.com ) is a full stand alone, lotta people use it on VW's, so if i do go stand alone, this will probably be it. even though i would have to convert to drive by cable (which is better)
what do you guys think? the sds is about $1200 with the MAP, coil packs, harness , ecu, everything.
basically seeing what the honda/acura crowd thinks of these systems, i wish hondata had a vwdata
any info would be nice, thanks
Re: Any of you guys heard of Split Second FTC1??? SDS ????? (evoeone)
there was one member that used it in his allmotor h22 civic...i dunno his name though..sorry
Re: Any of you guys heard of Split Second FTC1??? SDS ????? (rOby)
Hey, just to let you know im selling my sds for 850....Has everything including b-series pulley with magnets already mounted....Has a pretty decsent tune in it also..
on a stock ls/vtec motor on pump gas i put 292hrs 245 ft lbs..
This is my boys screen name...
[Modified by HybridCoupe, 7:08 PM 3/3/2003]
Re: Any of you guys heard of Split Second FTC1??? SDS ????? (HybridCoupe)
weejoeturbo
Engine Management and Tuning
01-05-2014 09:05 PM
