Swaped cluster on my hatch put in GSR cluster now......................WTF!!!!!!!!!!!!!!!!!!!!!! !!!!
From: 9/11/01 WTC Never Forget, United States Of America
here is the deal;
i put in my gsr cluster into my hatch now the only things working are:
the dim light/tach/brake light/check engine/oil light/trunk.hatch light.
the others are not working;
volts/water.cooling temp/fuel/high beam/turn signals/hazards
also i got to take out the speedometer cable but i cant get the vss out
could someone plz help me out...................ASAP
I don't know what directions you used to do the cluster swap.
this is what I have done.
trace the lights that are not working back from the back of the cluster to the
plug. then you know where on the plug they go. Do the same on the hatch's cluster.
then it's just a matter of wiring those wires to the right spot on the GSR cluster.
piece of cake.
piece of cake.
hey Spaceaballs if u have AOL Instant Message pls send me a message to: siderazeref9
I followed ghettocrxsi instructions..................
Have you tried talking to him? Did you double check all of your wires? There is other people who has done it also and double check their wirings to gettocrxs. If you do a search, you could find it. I just haven't gotten to the wiring part yet. Let me know what went wrong if you ever figured it out.
here is where you could see some pictures https://honda-tech.com/zerothread?id=274235
Mr. Red.
What gauge cluster plugs did you use? I'll be getting the 92-up civic and wondering if that is what went wrong?
[Modified by CrxSi10, 1:06 AM 3/5/2003]
Mr. Red.
Hey guys... look as tho alot of you guys are having trouble with the wiring issues.. I am going to update the wiring diagram here soon..
I found a few mistake if you need help I have the wiring **** right here in front of me.
Im me on aol im vwrabbit8v..
Also you cannot use 92-95 civic plugs for the cluster.. you have to use 94-99 integra and a 94-99 integra guage cluster.. If you use 00-01 they have a different pin config and it wont work with the 94-99 plugs. So if you guys have trouble pm me or im me
did you managed to get you cluster working ?
where is ghettocrxsi updated specs
[Modified by Camshaft, 1:50 PM 3/5/2003]
Damn! Just as I payed $20 for a 95 Honda Civic's gauge cluster plugs. Was very happy until I got home and they didn't fit.
Guess I just have to find the GSRs or will any 94-up Integra gauge cluster plugs work?
any 94-99 integra plugs will work.. also If you want my updated wiring diagram go to my website http://www.angelfire.com/dc/oregonimport/gsr.html. THats a direct link to the cluter page.. if u want to look around on the home page go to http://www.angelfire.com/dc/oregonimport/
importboi22
May 31, 2004 10:32 PM
