Shaft Play already?
I've got the basic t3/t4oe that comes w/ some of the pre-fabbed kits. I had the turbo on the car for one day, a little over 2 months ago. i am just now getting the car running again, and i noticed there is shaft play on the turbo! there wasnt any before, and there are fewer than 100 miles on the turbo. there is no play back and forth (<----> ), only up and down.
the only difference is that the houseings were rotated b/c of a different mounting position. Can that cause this? It's pretty noticable too. Is there any way to fix it w/o spending ~300 for a rebuild?
[Modified by CRX SiR T, 11:46 PM 3/3/2003]
it should be fine. Most used turbos that I hear of have some sort of minimal shaft play. When oil is pressurized into the center housing..this stabalizes the turbine form moving. If the blades are hitting the walls....that's a problem, but otherwise I hear its very normal. If you've pushed your turbo beyond normal driving and dragging I hear it happens....ANY OTHER ADVICES FELLAS?
[Modified by mamaboy, 11:49 PM 3/3/2003]
R6E6I6D
Aug 23, 2005 10:50 PM
