Trannies
Old Mar 3, 2003 | 10:20 AM
I Gotta Question's Avatar
Default Trannies
Is it true that you have to change the hubs on the hf to use an Si tranny or is this just some crap someone made up? Is there anyway around it?
Old Mar 3, 2003 | 12:05 PM
wronghand's Avatar
Default Re: Trannies (89_CRX_HF)
As long as you use your HF/STD axles you do not have to change the hubs.
Old Mar 3, 2003 | 01:20 PM
mr. carpenter's Avatar
Default Re: Trannies (wronghand)
i put a 91 si tranny into a 91 std w/out changing axels
Old Mar 3, 2003 | 01:50 PM
wronghand's Avatar
Default Re: Trannies (mr. carpenter)
That is what I said. He is wanting to put an Si tranny in an HF. As long as he uses his current axles he will not have any problems. The Si axles will not work on an HF/STD hubs.
[Modified by wronghand, 5:55 PM 3/3/2003]
Old Mar 3, 2003 | 02:06 PM
oh... thanks for the explanation. are you the only person allowed to give input?
Old Mar 3, 2003 | 02:15 PM
Okay thanks for the input and for you agreeing. Why won't the si axles fit the hf hubs? Is the hole to small? Can I drill the hole out?
Old Mar 3, 2003 | 02:26 PM
i believe it's different spline counts?
Old Mar 3, 2003 | 03:06 PM
zCivic's Avatar
Different Spline count and the HF/STD outer shafts are quite a bit smaller (more then likly because of the spline count). Here is a tip never try this HF/STD outer CVs in any hubs that are not HF/STD. I've done this bad, bad, bad and $$$$$$
soundman
10
Oct 25, 2004 06:25 PM
JDMDeakin
Aug 14, 2004 06:09 PM
pdiddyparsons
Feb 20, 2003 01:04 PM
pdiddyparsons
Feb 20, 2003 07:15 AM
pdiddyparsons
Feb 18, 2003 11:34 AM
