WTB: Oil Fittings and Misc Objects for Turbo Install
I need a 1/8" nspt T fitting for my oil feed as well as a Fitting for my oilpan. Don't know the exact thread/size but I'm using -10an line.
Also if anybody has good prices on a t3 gasket, bseries exhaust gasket, and oilpan gasket for a b18b. Figured I'd try here before the Honda Dealership. Thanks guys.
I can get you the oil feed line and oil return kit...
I can prolly throw in a few gaskets and misc as well..
IM me with what you have and what you don;t have, I'll fill in the blanks
stan
stan
My oil feed consists of:
npt/bspt convertor
npt fittings on -4an fittings (blue ones)
earls -4an fittings on ea end (red ones)
-4an ss line
Brass 1/8 -> 1/4" fitting to fit into turbo
My oil return consists of:
npt fittings on -10an fittings (blue ones)
earls -10an fittings on ea end (red ones)
-10an ss line
npt/bspt convertor
-4an ss line
-10an ss line
Also I forgot: My oil return flange has a little pipe welded on to it already. I would assume a gasket would be necassary for the oil return flange. I would need one of those if it was.
do you have 4an to 1/8NPT fittings? since u have female hose ends, and female tees and adapters..u need fittings to screw into the hose ends.
know what im talkin about?
The male end of the tee screws into the npt/bst convertor correct? And then a female piece on the tee for the stock oil sensor. Leaving another female piece on the tee open!! Crap. I guess I could get a 1/8" fitting from home depot. It was like $.80.
boostedBLUfg2
Apr 12, 2011 06:46 AM
