b16a sucks
Old Mar 3, 2003 | 04:40 AM
rZiViChatch's Avatar
Default b16a sucks
I own 88 civichacthback std, motor b16a j1 tranny out of integra xRi jdm. heres my time at the track.
left rigth
0141 123
r/t. .528 1.046
60. 3.373 2.923
330. 8.051 7.482
1/8. 11.574 11.050
mph. 70.38 69.74
1000. 14.560 14.122
1/4. 17.075 16.720
mph 89.33 87.06
the left car is mine, the right car is a acura 4 door sedan forgot what type of car it is. please help, tell me what's wrong with my car why is it so slow, every thing work fine, i have the motor for about a year it's also a stock motor the only thing i got is intake and exhust. any help please. thank you chris.
Old Mar 3, 2003 | 04:44 AM
wannab20hatch's Avatar
Default Re: b16a sucks (rZiViChatch)
You cant drive? That could be part of the problem. A friend ran friday at the track a crx with jdm b16 and ran 16.4 And that was his first time ever running the car at the track and with vtec messin up at half track.
Old Mar 3, 2003 | 04:49 AM
ricodemus's Avatar
I don't think much is that wrong with your motor. 3.373 is the worst 60ft time I've ever seen, and that has a lot to do with the driver. The other valuable number is your trap speed. 89mph isn't great, but you should be able to gain a couple mph if your 60ft goes down. I've read that every .1 you take off of your 60ft is .2 off your 1/4, which means you should have that car in the low 15s.
The launch is everything in our cars. Did you just dump the clutch and spin at the line? What kind of clutch? What tires are you running? I think these are what you should concentrate doing. rev to 3-4krpm and let the clutch out slowly to try and keep the rpm there while your getting traction. Once you get traction, you aren't far away from the vtec powerband and you should be on your way to a good run.
Old Mar 3, 2003 | 04:51 AM
Default Re: b16a sucks (wannab20hatch)
it's my 1st run at track also, but check my speed i'm going faster than the other guy on the right. i need more practice.
Old Mar 3, 2003 | 05:00 AM
REDBARON's Avatar
I've only ran my B16 CRX 3 times at the track and I ran a 16.2, 15.8, and then a 15.1. Now it wasn't my first time at the track, but it was my first with my CRX.
Like someone said earlier, it's all about the takeoff. I changed my method each run, and you can see the result. I ended up launching at 2.5.
PhantomEG's Avatar
WOW!You need to werk on your 60 ft. times the most. Your mph is not to bad tho,just practice and the times will get alot better!I ran a 15.2 my first time at the track and now with the same setup run 14.2 to high 13's at around 97 mph.1990 hb w/b16a and header and exhust.And i might add it's only about 1800 pounds
Old Mar 3, 2003 | 05:25 AM
USDM 4G VTEC's Avatar
i ran 15.9 @ 86mph...
with just intake on my SOHC VTEC
and i had a 2.3 60ft.
i say u dont know how to drive and et off the line.. sorry nuttin personal but its ok if it was ur first time.
just fix ur 60 ft and u will see differences
Old Mar 3, 2003 | 06:26 AM
sappsycho's Avatar
Default Re: b16a sucks (jdmef9boy)
How, may I ask, did you get your car down that weight? Is it a 1st gen? Does that include driver and fluids?
Old Mar 3, 2003 | 06:27 AM
EP3_05's Avatar
Drop that 60'. That is killing you. Other than that just practice and practice some more. My best time with the b16a in my 4dr was 14.8@94 with just i/e. I could have done better but my launches kind of suck. It is the launch that is killing your times and the engine is not at fault in this situation.
Old Mar 3, 2003 | 06:54 AM
Default Re: b16a sucks (91civic)
thanks evrybody for your info, i'm going back to the track sunday and get better times, and i'll practice some more to get better times, thank you.
Old Mar 3, 2003 | 06:55 AM
i'll post my next run also wish me luck.
Old Mar 3, 2003 | 07:14 AM
EF8_SiR's Avatar
What RPM is suggested for launching a b16 crx? I'm pulln pretty shitty times right now as well and I know for sure it's my launch that's causing it.
Drivetrain setup: Centerforce dual friction and Spoon flywheel
Tires and Suspension: Kosei K1, YokoA520, Tokico struts w/ ST springs dropped 1.2"
I read off a site that slippn it arond the 3000-3500 mark will provide for good results but at that mark there's still slippage occuring, but if i go lower i loose a lot of time getting my rpm up the band
Old Mar 3, 2003 | 07:23 AM
wuhungsixxx's Avatar
New User
your 60ft is ridiculous...its not your motor, its youd driving...and i thought my 2.6 60ft my first time was bad...go practice your lauches ...your good for at least a 15.0
Old Mar 4, 2003 | 08:55 PM
StorminMatt's Avatar
2.923 and 3.373 second 60 foot times? And I thought I was bad because I ran 2.5-2.7 second 60 foot times when I started going to the track! You REALLY need to look for ways to get these times down! Are you running stock 13 inch tires or some other crappy setup? This could be the reason for your problems. Someone else mentioned the trap speeds. These are also on the low side. And they could be caused by your poor launches. But then again, it could be other things. For instance, what RPM are you shifting at? With a B16A, you should get as close to the rev limit as possible. And the shift should be done as quickly as possible so as to spend the least amount of time possible without power.
Old Mar 5, 2003 | 05:51 AM
PhantomEG's Avatar
Default Re: b16a sucks (sappsycho)
Its a 1990 hb w/a 1st gen b16,for some reason its a REALLY strong motor! All i have in the car is my del sol seats and my dash which is home to some jdm goodies I stripped everything out the car ,like the sound **** on the floor"30 pounds" and cut about 100 more pounds of metal that was just in the way.Then i repainted it all and it looks great...And i might add thos times were on street tires and pretty sorrie 60 ft. times "2.3"... but hope i answered your question...
Old Mar 5, 2003 | 06:57 AM
4inspeed's Avatar
lol those are some great reaction times. (just messin around) but seriously you just need practice my first time at the trace my b16 rex ran a 15.0 and i couldnt better that, then my second time i went 14.8 consecutively, i didnt even have any mods then, im curiouse what i'll run next with the intake, exauhst act 6 puck, and slicks, any ideas??
Old Mar 5, 2003 | 07:06 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: b16a sucks (4inspeed)
i pulled a 13.9 in my 89 dx hatch (1925lbs without driver + 170lbs with) with I/H/E UR pulley, slicks with the b16a.
Old Mar 5, 2003 | 07:20 AM
Driven's Avatar
Default Re: b16a sucks (yebabee)
if you still think it sucks, i'll buy your car from ya for $2K.
Old Mar 5, 2003 | 08:53 AM
spankaveli's Avatar
left rigth
0141 123
r/t. .528 1.046
60. <u>3.373</u> 2.923
330. 8.051 7.482
1/8. 11.574 11.050
mph. 70.38 69.74
1000. 14.560 14.122
1/4. 17.075 16.720
mph 89.33 87.06
i wonder why
[Modified by spankaveli, 11:55 AM 3/5/2003]
Old Mar 5, 2003 | 10:28 AM
Malgerus's Avatar
Default Re: b16a sucks (spankaveli)
Hey I pulled 15.2 out of a sohc vtec with i/e stripped interior, so a B16A should be able to pull way harder than that. Is the motor healthy? Good compression?
Old Mar 5, 2003 | 10:35 AM
Hybrid Invasion's Avatar
Dude, just because you can't ******* drive, don't go knocking a motor that a lot of people have. Learn how to ******* drive, THEN determine if the motor sucks or not. If you're running the 1/4 mile in 17 seconds with a ******* b16, there is either SERIOUS mechanical problems, or you have absolutely no ******* clue what you're doing. Research a little more before making a thread talking **** about the b16. You should be running mid-high 14's...jesus, this **** pisses me off
Old Mar 5, 2003 | 11:29 AM
Malgerus's Avatar
Default Re: b16a sucks (Hybrid Invasion)
hey go easy on the guy. I'm sure that he didn't intend to offend you. But you do have a point...
Old Mar 5, 2003 | 11:32 AM
V3locity's Avatar
Default Re: b16a sucks (Mr. S)
i'll buy the b16.......since it sucks soo bad!
Old Mar 5, 2003 | 03:00 PM
sorry, just kinda tweaked me.
Old Mar 5, 2003 | 04:00 PM
Patch's Avatar
Some people don't deserve B16s...
