2000 civic ex rear lower control arms
Old Mar 3, 2003 | 02:39 AM
JICB16B's Avatar
Default 2000 civic ex rear lower control arms
i am going to do the energy suspension hyperflex kit and also convert the drums to discs. the question i have is that the lower control arms on my civic are the stameped ones and they do not make bushings for the stamped control arms so can i use a 94-01 integra lower control arms cause the make a bushing kit for that can i do this and also when i order a rear sway bar which one do i order it for civic or intrgra
[Modified by b18a1boosted, 3:40 AM 3/3/2003]
Old Mar 3, 2003 | 03:48 AM
wilsel's Avatar
Default Re: 2000 civic ex rear lower control arms (b18a1boosted)
If your going to get an ITR rear sway bar get teg LCA's, and order the Teg Energy Suspension kit. That's what I just finished. The only bushings that you can't use are the shifter bushings, unless you have a swap already. If you need Civic LCA's I have a set for sale from a 95 EX.
Old Mar 3, 2003 | 04:15 AM
shawnhayes's Avatar
Default Re: 2000 civic ex rear lower control arms (wilsel)
Notice - he has a 2000 Civic.
Ever work on one of those? I'm guessing not.
Integra lower control arms WILL NOT FIT a 2000 Civic. The length is different.
Energy suspension does make a master set for your car, but I have not installed one, and I suspect that you are correct about no polyurethane bushing being available for that arm.
My best $0.02? - Look for aftermarket control arms with different setups for bushings. (perhaps poly already installed).
Shawn
Old Mar 3, 2003 | 06:53 AM
wilsel's Avatar
Default Re: 2000 civic ex rear lower control arms (shawnhayes)
Shawn
My bad. Look at getting some SRR LCA's then.
Old Mar 3, 2003 | 07:26 AM
Chris(Youngstown)'s Avatar
I don't know what your budget is. If you're a baller though, AEM and Brembo both make disc conversion kits that are bolt-on apps. Modacar.com has them, and just about every local shop in the known world carries AEM. All in all though, I'd try and make the Teg conversion work every which way you can come up with. It's less expensive for sure.
Old Mar 3, 2003 | 09:00 AM
misledyouth's Avatar
New User
Default Re: 2000 civic ex rear lower control arms (Chris(Youngstown))
just hook up soem si control arms or even dx ones. I can buy bushings for my dx control arms.
jesse
passwordjdm
11
May 11, 2012 07:20 AM
Drew2o2
Suspension & Brakes
Aug 4, 2010 09:17 PM
ED9man
Apr 11, 2008 04:22 PM
krkline2gdsm
Suspension & Brakes
Oct 26, 2007 05:25 AM
mental1
12
Feb 7, 2005 06:43 PM
