Car doesn't crank......
Check for voltage at your starter connections. Then check for continuity between the starter and its ground. My friend's ground cable to starter corroded too much and wasn't letting it get any juice. They replaced the starter 3 times before they figured it out.
Do you hear anything at all when you turn the key? Do you hear a faint clicking? Do your accessories's lights turn off?
If so, check your main engine grounds like the others said. Check the main harness ground near the thermostat.
Also...just whack the end of the starter hard with a hammer. Actually, that sometimes works if the starter is a bit old or it's cold outside.
Good luck.
Good luck.
Good luck.
Good luck.
If that doesn't work, does it mean it's the starter?
if the spade connector is off, then will anything happen? shouldnt nothing happen? i have this problem, sometimes it starts and sometimes it pisses me off.
Ok, it's the STARTER. I checked the ground harness, the battery terminals (pos. was lose, had to put a piece of metal between the terminal and battery post to secure it tight.) I supect the terminal being lose shorted my starter and thus killed it. I also check the starter fuse and gave it a jump start. Nothing work until I wacked the starter a few times with a long metal stick. The car then starter. THANKS EVERYONE FOR THE HELP!
Anyone know where I can get a rebuilt or remanfacteur starter for a decent price? DOn't want to pay $200+ for one at my local auto-part store.
Aquila
20
Sep 28, 2016 05:59 PM
