Quick question about axles!! Please look.
Well if you have a B16 and no 93 Civic came with a B-series then they will not work. I think 00 Si axels might work though.
[Modified by 89B16HB, 3:44 AM 3/3/2003]
Well if you have a B16A in a STD (I will assume u didn't do the swap) then you either have had the knuckles switched out to Si ones, or you have some frankenstein axels with the STD outer part, but I HIGHLY doubt that.
OK, damn it, I have a STD. I have a D15B1 in the car! I was going to put a B16 in hence my screenname. Can't anyone give me an answer????
I was under the understanding that CRX HF axles and Civic STD axles were the inferior smaller ones...therefore you'd need to use the ones specifically specified for that application.
~Alex
~Alex
93eg-EKhybrid
Mar 2, 2003 07:51 PM
