FS: Rechipped to DOHC/SOHC VTEC OBDI 92-5 ECU
92-5 ECUs rechipped/reprogrammed to work as DOHC VTEC or SOHC VTEC (orignally ECUs where P28/P91/P27 and alike. Includes three different chips from the choices below: Superchips, J's, JUN, Mugen, Feels, PYR/Prospeed, Skunk2 (all are different as far as mapping (fuel and ignition))
-Superchips = based on the Euro P30 program (stock like fuel and ignition maps - fianally you can have great mielage on your B16A)
-Mugen N1/Skunk2/Feels =rather rich and all out NA program
-PYR = based on the Mugen but slightly leaner
-Js/JUN = streetable low maps after vtec race maps
Can be used on all OBDI DOHC VTEC applications and OBDII motors with harness converter (SOHC VTEC chips avalible with the ecu as well). made to run a B16a, b18c, b17a in any 92-5 car or with harness converter on a 96+ cars, including ITR, CTR, Si/SiR and even EX/Si and 1.6 el ...the latter can be equipped with SOHC VTEC chips which I also have....
Please no flakes, no COD or Paypal only International Money Order or cash if you want to pick it up
for refrences please check here (civic forum) or hybridhonda.jp or hybridgrage.com
Price is $165US shipped (that includes the ECU + 3 programs + shipping)
!!!!New harness converters with the purchase of the ecu they are only $115US!!!!
Also offered will be DIY harness kits which will include all necessary parts + instructions @ $85US
Avaliable will be the 88-91 to OBDI, 96-8 to OBDI and 99-01 to OBDI versions.
btw. I am not affiliated with the Honda Motor Co, Mugen, Feels, Spoon, Skunk2, XS Engineering, PYR, JET, J's Racing, RPT and Vision or any other company mentioned. Names, performance or capability of programs does not reflect image of the companies or their actual property.
Modified by eg6ajk at 7:30 AM 6/9/2003
regular shipping thats included in the price takes about = 4-7 business days
for an extra $15-20US you can have it there overnight/2days - depending on location
Are these legit copies of these programs? Or are you bootlegging/sellign hem illegally?
Just like your boost code, which uses modified honda code, I use modified spoon/mugen/honda/jun code.
as far as other issues:
basically any chip that is a modifies part of honda code is a direct infringement of Honda motor company's intellectual property.
Can you explain how this works? I'm looking for chipped p28 ECU so I can run B16B on my 95 Del Sol. If I purchase from you, you'll provide me w/ 3 different chips & I can then place 1 of them into ECU. Would I be able to swap to 1 of other chips @ later time?
----- Antony
----- Antony
the ECU is socketed and can have chips swapped in few seconds. simply remove the the installed chip by pulling it out of the socket and press in another one in.
john the copies of the programs are from my own ECUs which I owned at one point or another. programs are not straight copies of the ROMs, but can be. I don't claim these are Feels or Mugen chips. they are ALIKE.
I'll give oyu the benefit of the doubt
<BLOCKQUOTE>quote:<HR>
You are 100% correct, but the big difference here is honda doesnt care, spoon, mugen, skunk2 DO care. But since you kno who I am, you cant be all bad
<HR></BLOCKQUOTE>
its true but the funny thing is that skunk2 ripped off the Mugen program (change the simple variables (vtec/rev limit and disabled a sensor or two)
changed to link
http://www.we-todd-did-racing....3D%3D
Modified by eg6ajk at 7:27 AM 6/9/2003
<HR></BLOCKQUOTE>its true but the funny thing is that skunk2 ripped off the Mugen program (change the simple variables (vtec/rev limit and disabled a sensor or two)
changed to link
This guy is legit, I wasj ust checking. Free bump for jo0
- good stuff as far as your boost code.
one chip is always installed the other two are there for you to try and use. sort of match better to the situation.
I have 8 instock. pm or email : gtssport@yahoo.com
[Modified by eg6ajk, 9:48 AM 3/19/2003]
$165 for ecu and 3 chips...
questions, is the ecu already prepped for chips (socket and etc)... also are the ecus p28 or p72?
*edit - if prepped for the chips, is it socketed or does it include a zif socket or a standard socket?
[Modified by 1.8T_EG, 10:26 PM 3/24/2003]
yes, ECU is socketed (of course tested) and simply plug and play (one chip present) other two are swapped in. I use standard sockets. ZIF can be installed at an extra cost (i don't personally like it on very stiff cars on public roads)
ECUs are P28/P91/P27/P07 sohc vtec variety reprogrammed to work as DOHC or SOHC VTEC ECU.
