Koyo Radiator ?
I want to run a Koyo radiator in my 4th gen cause my stock rad. is cracked.
Which fans do you use? I'd rather not spend $300 for the FAL or Fluidyne.
I just would like some info on these Radiators before I buy it, thanks.
Hey man, I actually JUST got back from the track. I was talking with an instructor about this very topic. He did not recommend the Koyo or Fluidyne. He said that the OEM one should be fine.
He is building up a CRX as a race car and that's what he got . He said that the OEM one is sufficient.
I was having he same dilemna sice I am going to be using my car for track/autoXs/daily driving. Honestly, I THOROUGHLY trust this guys judgement.
What do you plan on using your car for??
Stock is more than suffecient, http://www.ebay.com is your friend
I was wondering if it is better for your engine to run a bigger one cause either way I have to buy a radiator. I am only planning on bolt ons and a mild build but I not going to run a real high compression ratio or boost.
I may just get a stock one but I would rather pay the extra $$$ if it will help my engine run cooler.
Thanks for help.
Thanks for help.
Which regulator sensor do I need?(I haven't heard of this some don't blame me for the stupid question) I can get a better thermostat. Does the high pressure rad. caps help or is it a gimick?
I will probably just run a stock one that doesn't leak
spoon
Gabe
