best b20 block
Unless you're getting a really good deal on the B20 you can probably get and LS block and sleeve it, bore it out to 84 or 85 for the same price if not a bit more
B20-$800-900
B18 $50-150
Sleeves 600-800
A sleeved block is better and you won't have the crank case pressure problems that the B20 is nototious for.
If you got with the B20....like mentioned earlier, the B20Z will give you more compression...but the stock pistons in both suck! You'll have to cut reliefs in them if you run an aggressive cam. I'd get a B18, sleeve it, bore, pistons, etc for 1500ish and call it a day
B20-$800-900
B18 $50-150
Sleeves 600-800
andrearcher2003
Sep 27, 2011 04:15 PM
TypeR0149
Aug 22, 2001 12:32 AM
