Will a P72 ecu run my H23..
Old Mar 2, 2003 | 03:04 PM
BoostedH23a1's Avatar
Default Will a P72 ecu run my H23..
well i got the hondata ready to go... just wanna make sure the ecu i bough works.. if it will should i plug in the hondata..
Old Mar 2, 2003 | 04:09 PM
symba's Avatar
Default Re: Will a P72 ecu run my H23.. (BoostedH23a1)
Yes, p72 is fine...In fact it's the only ECU that will allow you to maintain your secondaries.
Old Mar 2, 2003 | 04:15 PM
IloveNewt's Avatar
thast what silverludesi used for my hondata
Old Mar 2, 2003 | 05:25 PM
Default Re: Will a P72 ecu run my H23.. (MordecaiPSI)
will it idle and **** or will i have to install it in a parkin lot at the tuners place
Old Mar 2, 2003 | 05:31 PM
TurboDC4's Avatar
Should idle fine, we put a chipped one in a friends accord and it worked great!
Old Mar 2, 2003 | 07:02 PM
UberTeg's Avatar
if you dont chip it with h23 fuel maps, it will idle like **** cuz its running too lean (approx 21% lean). If you dont want to chip it, force your car into limp mode, that will give you enuf fuel to drive around.
DLB1994
May 30, 2016 07:14 AM
WiteSiprelude
Sep 28, 2005 07:00 PM
1995H23Lude
Oct 11, 2004 09:03 AM
prjct92eh2
Mar 23, 2004 09:04 AM
BoostedH23a1
Nov 26, 2002 01:32 PM
