Car Sound Cat Question
Which Car Sound Cat should I try to get?
I am getting a 3 inch but they have 2 series avalible:
http://www.car-sound.com/04product/04universal.htm
93500 Series Converter - up to 460CID 7.9L and 7000 lbs MAXIUM EPA / Carb COVERAGE
94000 Series Converter - up to 360CID 5.9L and 6000 lbs MAXIUM EPA / Carb COVERAGE
However, the 9400 is avaliable in the following instances:
Which do I need considering I have a GSR thats has the 00-01 computer and o2 sensory crap?
some more about ODBII and cats: http://www.car-sound.com/04product/04obdii.htm
Most people get the 94006 and have the 02 bosses welded on. It's more expensive to buy the ones that come with the bosses pre-welded. I haven't heard of anyone using the 93500 series, but I believe the 53000 series is a better fit for Hondas, is less prone to rattle, but doesn't flow as well as the 94000s. You can have the muffler shop spot weld the heat shield ahead of time to help prevent the shield from rattling. If your car isn't tuned properly, you will lessen the life of the converter and it may rattle from the inside. BTW, it's not installed yet, but I bought my 94006 from this guy:
http://cgi.ebay.com/ebaymotors/ws/eB...&category=6771
He has the best prices I've found and can even send you the 02 bosses for $5 extra.
yea, I actually called him this morning and discussed it with him. he said it would be cheaper to get what he has (94009 3" High Flow) and add 2 o2 bosses. so thats what im going to do.
BTW, the 94000 and the 93500 are the only ones offered in 3", so the 53000 is
Yeah, you almost need a translator when talking to him, but he's really cool and takes the time to answer your questions.
