Honda S2000 Honda S2000
????Help With (SW388) Tire Size????
Old Mar 2, 2003 | 07:58 AM
Black_eh2's Avatar
New User
Default ????Help With (SW388) Tire Size????
I have just purchase a set of 16' Spoon Wheels and don't know what size tires to put on them. The tires I'm buying are Potenza S03. I have also lower my car with a set of kg/mm springs I know a lot of you s2000 owners out there have the same set-up so please reply. I want it to look good at the same time No Scratching on the fender walls. Please Reply Fast........
Old Mar 2, 2003 | 10:24 AM
Black_eh2's Avatar
New User
Default Re: ????Help With (SW388) Tire Size???? (SleeperEG6)
ttt...none?.common..guys.
Old Mar 2, 2003 | 12:54 PM
S2Thizzle's Avatar
Default Re: ????Help With (SleeperEG6)
Front: 205/55/16
Rear: 225/50/16
I'm running the SW388 (+35 offset front, +45 offset rear) with KG/MM DR21 Race springs.
Old Mar 6, 2003 | 06:57 AM
Schatten's Avatar
Default Re: ????Help With (S2Thizzle)
"Front: 205/55/16 Rear: 225/50/16"
THAT IS INCORRECT! however, it is ONLY correct if you are running OEM S02's. If you go with S03's or ANY OTHER TIRE, you must use 245/50/16's in the rear. The OEM S02's are sized at 225/50/16, however they are sized more like a 250/50 if such a tire existed.
Old Mar 6, 2003 | 08:11 AM
J'sAP1's Avatar
Default Re: ????Help With (Schatten)
I have a 2.5 inch drop and my rear fenders are rolled and I am using stock SO2s. I wouldnt go to any other tire because the other ones that I have tried rub pretty bad. If you use other than OEM tires you must go with a 245/45/16 rear the front you can leave the same.
Here is a quote from http://www.s2ki.com tire forum.
"There has been lots of discussion and I wanted to help clear this up.
This advice applies to the Stock Rims, with NON-OEM tires
If you are not running the OEM tires on the rear of the S2K, you should be running a 245/45/16 in the rear.
Our stock 225 is NOT a real 225 and has a 8.5" contact patch which is the same as just about all other 245's out there.
205/55/16 in the front."
[Modified by SpoonS2000, 5:17 PM 3/6/2003]
Old Mar 6, 2003 | 09:39 AM
PROFILES2000's Avatar
Default Re: ????Help With (SpoonS2000)
wow spoon the more and more i see your car the more i like it
Old Mar 8, 2003 | 09:19 PM
M-Type's Avatar
Default Re: ????Help With (PROFILES2000)
have you guys seen the new spoons? they have "Spoon" written in yellow on the spoke
Old Mar 9, 2003 | 07:33 AM
Black_eh2's Avatar
New User
Default Re: ????Help With (M-Type)
Those came out way back they are just bringing it back.
midori_rivas
Sep 8, 2014 07:17 PM
ayydrinn
Jan 12, 2012 12:17 PM
cheese steak Nazi
Honda S2000
Jul 10, 2007 09:22 AM
zexifiedlude
Jan 26, 2006 03:29 PM
aznwash3wboi
Sep 12, 2005 01:12 AM
