obd 1 distributor,engine harness,2.5carsound cat+testpipe, 88-91 eq optional console, gsr mains and
New Golden eagle gsr block , you pic the bore size!!!look here https://honda-tech.com/zerothread?id=432694
For sale... new 2.5 in carsound cat with testpipe and hardware with donut gasket(obd 1) sold
used obd 1 b series distributor 150.00sold
used 88-91 civic optional Eq/ash tray/lighter console 120.00 shipped sold
complete set 95 integra gsr main caps with block girdle..make offer
used complete 92 teg obd 1 gsr engine harness.sold
used pr3 obd 0 ecu.sold
used 90-91 si hatch engine wire harness..bo
used obd0 b16 distributorsold
[Modified by Tbone, 3:17 PM 3/5/2003]
[Modified by Tbone, 9:24 AM 3/10/2003]
[Modified by Tbone, 9:15 PM 3/11/2003]
Modified by Tbone at 10:10 PM 4/13/2003
I'll try to get some tommorow. The cat and test pipe were made by smsp btw. both new with all the hardware and donut gasket. They measure 16 1/4 in long and have 1 o2 bung on each.
ok cool i'll wait for those pics. oh this is a custom cat? what application was it made for? are the bungs currently plugged or open? cuz i'm obd1 so i dont really need them. thanks
The cat is custom, it measures 16 1/4 long. Gsr cats are usually 17 in i beleive. I run a long thbe header so I had it shortened . If its a problem I can send them back to smsp and he will make the needed adjustments to make it 17 again because he's my buddy
. I had the exta bungs put in for my o2 for my air fuel gauge, it also helps when your on the dyno to run a wideband. I dont have plugs for them but you can just get a bolt and cut it down and put it in the opening. Or just stick a old junk o2 in there.
here are pics of tbone's carsound cat and the test pipe. please defer all questions to tbone about the parts. i had the parts so i took the pics for him.
may still be interested in cat. how much?
now the cat and test pipe are two different things right? or the pipe is hidden inside the cat shields? if they're seperate how much for the cat alone, no pipe no hardware
look up at the pics , the cat is the one with the heat sheilds and the pipe, well its the one that looks like a pipe
. I'm not looking to seperate the package though ,sorry.
cat + test pipe
obd 1 dist
eq cluster
all sold .
still have the ge gsr block , buyer flaked.
obd 1 dist
eq cluster
all sold .
THEhomelessONE
Northern California (Sales)
14
May 31, 2009 08:59 PM
