Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Lug Nuts backing out
Old Mar 1, 2003 | 06:49 PM
Andrew 825SM's Avatar
Default Lug Nuts backing out
Ok I went to evolution autox school yesterday and learned a lot of new things. Total runs was about 25 or so. So today I show up to Hollywood park for practice and checked my lugnuts to see if they were tight. Well what do u know, the left front side of the wheel has 3 loose lugnuts (can unscrew with my hand). Didnt have my key so had to run to kragen to buy a set of 4 new lugnts. So after 6 runs at practice, I check my lug nuts again and well what do you know, I was able to unscrew one with my hand, and the other ones were loose when I retorqued them. Does anyone know why the lugnuts on my left front wheel keeps backing out?
Old Mar 1, 2003 | 07:20 PM
Tyson's Avatar
Default Re: Lug Nuts backing out (Andrew 825SM)
check to see if your torque wrench is in spec by using someone elses.
Old Mar 1, 2003 | 07:26 PM
the DR.'s Avatar
Default Re: Lug Nuts backing out (Tyson)
try someone else's torque wrench like tyson mentioned, but.. if you torqued all your lugnuts with the same torque wrench and only the left front is backing out, i'd have to say take a good look at the studs... and how many ft/lbs are you torquing(sp) to?
Old Mar 1, 2003 | 07:33 PM
urbanlegend21's Avatar
New User
Default Re: Lug Nuts backing out (SlicedBread)
are the lugs on new rims?if the rim has paint on it where the lugnut touches the rim then scrape it off, this can cause lugnuts to loosen also
Old Mar 1, 2003 | 07:35 PM
Tyson's Avatar
Default Re: Lug Nuts backing out (urbanlegend21)
oh yeah, do the lugnut seating match the wheel? taper vs acorn.
Old Mar 1, 2003 | 08:30 PM
MattG's Avatar
New User
That was my first thought.
Old Mar 1, 2003 | 08:47 PM
Default Re: Lug Nuts backing out (MattG)
Its only happening to one of my wheels though. I have owned my Kosei K1 rims for about 5 months now and I do not think the torque wrench is my problem cause it is fairly new. One thing I noticed about the lug nuts were that there was some paint shavings on them from the rim.
My lugs are acorn shape. Are they the correct one for kosei rims?
Andrew
[Modified by Andrew 825SM, 9:48 PM 3/1/2003]
Old Mar 1, 2003 | 08:49 PM
Reid's Avatar
Global Moderator
No, most aftermarket wheels (like your Koseis) require tapered lug nuts.
Old Mar 1, 2003 | 10:44 PM
tilt's Avatar
Default Re: Lug Nuts backing out (Reid)
Ive experienced acorn lugs on aftermarket wheels b/c the previous owner had them on, and I didnt know the difference for the longest time. Problems I had were lugs backing out and threads stripping. Make sure you have the right lugs Stock - acorn, aftermarket - almost always conical/tapered.
Old Mar 1, 2003 | 10:52 PM
Reid's Avatar
Global Moderator
Default Re: Lug Nuts backing out (tilt)
Stock - acorn
This is true when dealing with Hondas.
Other makes vary.
Just a heads up for the non-Honda enthusiasts who frequent the board.
Old Mar 2, 2003 | 05:15 PM
XR4racer's Avatar
Default Re: Lug Nuts backing out (George Knighton)
As Urbanlegen21 hinted, lug nuts backing out is a particular problem with Kosei until you wear down the paint where the lug nuts are making contact w/the wheel.
New Kosei owners are very close friends with their torque wrenches.
Here is your answer.
Old Mar 2, 2003 | 05:37 PM
MattG's Avatar
New User
Default Re: Lug Nuts backing out (XR4racer)
I have new K1's with my summer tires. Would you suggest possibly using sandpaper to carefully remove or scuff up the paint where the lug nut seats? Would any compound help on the lug? I would think most threadlockers would make a mess and gum up the threads and generally be not a good idea? Thoughts....
Old Mar 2, 2003 | 06:18 PM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
I found the Kosei-Acorn lugnut incompatibility thing out the hard way...
Old Mar 2, 2003 | 08:07 PM
XR4racer's Avatar
Eventually the paint will begin to peel off where the nut seats anyway, but if you don't sand it off, you have to keep check on their tightness and re-torque as necessary. I would just sand out the taper, where the nuts seat. I also use a little bit of antisieze on the threads... just a little to prohibit rust and corrosion. Torque wrench is always your friend.
Old Mar 3, 2003 | 09:04 AM
mph6563's Avatar
Among them, "What happens to an RX-7 on Hoosiers when its lugnuts fail during cornering." I have a feeling that inspired your lugnut inspection?
Old Mar 3, 2003 | 11:14 AM
Default Re: Lug Nuts backing out (mph6563)
Oh man, that was a horrible sight to see! I was the person lining up for the next run and saw ur car fly up into the air right in front of my eyes. It was an unbelievable sight. So how is your car, is everything ok with it? I think if I had not witnessed that accident, I wouldn't have checked my lugnuts the next day at practice. That could have resulted in my wheel coming off as well because three lugnuts were very loose on one of my rims. So you actually saved me from disaster and I thank you for that.
Old Mar 3, 2003 | 11:59 AM
mph6563's Avatar
Wasn't my car, thank God. I drive the del Sol. I don't know who the RX-7 driver was; I don't remember seeing him or his car at CSCC events.
Old Mar 3, 2003 | 12:05 PM
Oh, hey whats up Matt! Did you stay for the fun runs on Sunday. It was a blast! For some reason I stressed out about competing and hitting cones that I drove very slow times during the comptetion. But on the fun runs, I ran 3 sec faster. Now why couldn't I do that b4!
Old Mar 3, 2003 | 12:13 PM
mph6563's Avatar
Hi Andrew... I didn't stay for fun runs because I ran in the morning and didn't feel like sticking around. So I only totaled 39 runs for the weekend. Life's hard.
On Sunday, I didn't really see any improvement from the school relative to the fast people in my class. I think part of the problem is that I improve too slowly. I can do 10 runs and shave off a second (or at least half) every time, so with just three runs I'm still slow. But if you look at the fast guys, the first run is slow, then the next two are both fast and quite close to each other, which says to me that they can dial it in right away. I need to work on doing that.
mnbvcxz358
Jul 20, 2010 10:56 AM
nsxtasy
Aug 27, 2008 10:45 AM
LX4CYL
11
Jun 3, 2005 09:44 AM
jdmb18c
Apr 5, 2003 09:27 AM
WTypeRogerX
Feb 20, 2003 10:02 AM
