B20 Swap info
Is there a website I can go to to find complete information for a B20 swap? I am going to need a complete list of parts that will be needed along with tech information. If it matters at all I am planning on a b20 non vtec. Any help is always appreciated.
I'm not going to sit here and tell you all of the obvious stuff, just some of the stuff I can remember that I know you will need.
B series front tranny passenger side bracket.
99-00 Si rear tranny mount.
The little bracket on the driver side uppper mount from a 99-00 si.
B20 lower and upper radiator hoses... All I can think of off the top of my head.
This swap is the same thing as any other b series swap.
You'll need a LS Intake manifold
B series engine mounts
Integra shift linkage/ or 99-00 Si
Any B series axles and corresponding intermediate shafts (91-93 teg axles work too i think?)
any B series headers
Any B series transmission
LS ECU
I think I'm missing something but someone can fill you in
LS ECU
Im not postive on this but pretty sure, if u just buy the mount kit from HASport the mounts actually lower the motor enough so you won't have to get the LS intake manifold. You can call and find out heres the link http://www.HASport.com
I don't think the hasport kit will lower it that much. If you look here in b20 tech, http://hybrid2.honda-perf.org/tech/b20/ you'll see how tall the thing is compared with the ls intake manifold.
jdmmdg421
May 24, 2013 11:33 PM
