Need Help,Car won't start.
Old Mar 1, 2003 | 02:55 PM
bLuEciVicGuY's Avatar
Default Need Help,Car won't start.
When I put the key in the ingintion all it do is crank.It just make click noises and won't start.What could it be.My battery is still good so I don't know what else it is.Any advice is helpful so tell me anything.Thanks in advance.
Old Mar 1, 2003 | 03:02 PM
eg_nezay's Avatar
Default Re: Need Help,Car won't start. (bLuEciVicGuY)
When I put the key in the ingintion all it do is crank .It just make click noises and won't start .What could it be.My battery is still good so I don't know what else it is.Any advice is helpful so tell me anything.Thanks in advance.
so does it crank or not? does the motor turnover? or just makes a click noise?
sammysnakes's Avatar
is your fuel pump priming?
Old Mar 1, 2003 | 03:07 PM
EK MONEY's Avatar
Default Re: Need Help,Car won't start. (chainsaw)
battery
Old Mar 1, 2003 | 03:37 PM
RaIn's Avatar
Default Re: Need Help,Car won't start. (Peagreenhatch)
Try push strating it and get your alternator tested at discount for free.
Old Mar 1, 2003 | 04:04 PM
Default Re: Need Help,Car won't start. (eg_nezay)
yes it just make a click noise.
Old Mar 1, 2003 | 04:16 PM
Archidictus's Avatar
Unceasing Measure
The clicking is not "turning over". That's your starter trying its damndest to start your car without the help of your battery. Get a new battery and your problem will be solved.
Old Mar 2, 2003 | 08:59 PM
Default Re: Need Help,Car won't start. (Archidictus)
THanks for the info guys.I'll let you know what it is when I fix it.
Old Mar 2, 2003 | 09:18 PM
BauleyCivic's Avatar
Risky Business
either battery or starter...most likely battery...
Old Mar 2, 2003 | 09:26 PM
aw1234dude's Avatar
Default Re: Need Help,Car won't start. (BauleyCivic)
My geo Prizm (aka pimp g-dog ride) did the same thing when the starter went out. It just made the constant clicking noise while i tried to start it. I dunno it probably could also be your batt.
Old Mar 3, 2003 | 11:59 AM
Default Re: Need Help,Car won't start. (aw1234dude)
Don't know what the problem was but after 30min of hiting the starter and stepping on the clutch my car started up.I think I might have a bad starter cause the battery is kind of new.thanks everyone that helped me out.
AZ-Accord
Sep 13, 2012 01:01 AM
.b20coupe.
16
Sep 21, 2011 08:39 PM
egtony
May 18, 2009 09:58 AM
Hatchman98
Apr 24, 2007 06:54 AM
CBS2000
Honda S2000
11
Apr 13, 2006 03:58 PM
