B16A1 in 5th gen. hatch
Old Mar 1, 2003 | 01:52 PM
Hondasaurs's Avatar
Default B16A1 in 5th gen. hatch
Ok guys, I know this has been discussed before, but I just need some confirmation here. A buddy of mine got a great deal on a 1st gen. B16. He already ordered the hydro-cable conversion kit from Hasport. What else does he need? I know it has to go OBD-1 to non-OBD, but what mounts are used? I just want to make sure he has the right stuff before he gets into the swap. Thanks guys.
Old Mar 1, 2003 | 01:53 PM
Nine's Avatar
Default Re: B16A1 in 5th gen. hatch (ZC_CRX)
You should be able to use the stock mounts.
Old Mar 1, 2003 | 01:56 PM
Hondasaurs's Avatar
Default Re: B16A1 in 5th gen. hatch (Nine)
So then here's the list:
hydro to cable kit
OBD-1 to non-OBD conversion harness (?)
stock mounts will work
If there's anything to add to the list let me know.
Old Mar 1, 2003 | 03:35 PM
rocco's Avatar
Stock mounts won't work,the motor should have the jdm ones but if it doesnt,tell your buddy to add some HAsport customize mounts to his order list.
Old Mar 1, 2003 | 04:31 PM
Hondasaurs's Avatar
hydro to cable kit
mounts that come with the engine will work
Old Mar 1, 2003 | 04:35 PM
OC 335i's Avatar
hydro to cable kit
If there's spare money left over... You may want to do the clutch and or flywheel at the same time. Other stuff are also simple to do (not to mention save time and money) change with the motor out, timing belt, header, etc..
Old Mar 1, 2003 | 04:48 PM
fowler!'s Avatar
Default Re: B16A1 in 5th gen. hatch (MEGA EK)
hydro to cable kit
Everyone is giving you shitty information.
1. You need OBD 1 injectors and an OBD 1 distributor.
2. The mounts that come with the motor will not work (unless the motor comes from an SiR II).
You need to find motor mounts from any 94-01 Integra.
3. You don't need an ecu conversion harness. Just run a chipped OBD 1 vtec ecu and you're fine.
4. Why are you running a cable transmission? Just get a Hydro tranny.. much less ghetto..
Old Mar 1, 2003 | 07:16 PM
UpstateCivic's Avatar
Default Re: B16A1 in 5th gen. hatch (fowler)
hydro to cable kit
The guy got a really good deal on a b16a1 from one of our friends, so he's just gonna get the HASport conversion kit. Yeah it's ghetto, but when money's tight, ya gotta do what ya gotta do. So here's the final list then:
-HASport conversion kit
-Mounts from a 94-01 integra
-chipped OBD1 vtec ecu
-OBD 1 injectors and distributor
Hopefully this is all of it. If there's anything else missing let me know so I can tell him. Thanks guys.
[Modified by UpstateCivic, 11:31 PM 3/1/2003]
Old Mar 1, 2003 | 07:55 PM
cnydelSolHybrid's Avatar
Default Re: B16A1 in 5th gen. hatch (UpstateCivic)
just get that beotch to my swap heaven and let me at it with the welder.
pitoracing24
Feb 13, 2008 08:10 PM
swap0em5out
Mar 28, 2006 06:18 PM
B18 CYA
Mar 24, 2006 03:23 PM
MR. BAR
Apr 29, 2005 01:08 PM
rexnst9
Feb 27, 2004 04:10 PM
