B16A1 in 5th gen. hatch
Ok guys, I know this has been discussed before, but I just need some confirmation here. A buddy of mine got a great deal on a 1st gen. B16. He already ordered the hydro-cable conversion kit from Hasport. What else does he need? I know it has to go OBD-1 to non-OBD, but what mounts are used? I just want to make sure he has the right stuff before he gets into the swap. Thanks guys.
Re: B16A1 in 5th gen. hatch (Nine)
So then here's the list:
hydro to cable kit
OBD-1 to non-OBD conversion harness (?)
stock mounts will work
If there's anything to add to the list let me know.
hydro to cable kit
Re: B16A1 in 5th gen. hatch (ZC_CRX)
Stock mounts won't work,the motor should have the jdm ones but if it doesnt,tell your buddy to add some HAsport customize mounts to his order list.
hydro to cable kit
mounts that come with the engine will work
hydro to cable kit
hydro to cable kit
hydro to cable kit
1 Post
Re: B16A1 in 5th gen. hatch (MEGA EK)
hydro to cable kit
hydro to cable kit
1. You need OBD 1 injectors and an OBD 1 distributor.
2. The mounts that come with the motor will not work (unless the motor comes from an SiR II).
You need to find motor mounts from any 94-01 Integra.
3. You don't need an ecu conversion harness. Just run a chipped OBD 1 vtec ecu and you're fine.
4. Why are you running a cable transmission? Just get a Hydro tranny.. much less ghetto..
Re: B16A1 in 5th gen. hatch (fowler)
hydro to cable kit
Everyone is giving you shitty information.
hydro to cable kit
-HASport conversion kit
-Mounts from a 94-01 integra
-chipped OBD1 vtec ecu
-OBD 1 injectors and distributor
Hopefully this is all of it. If there's anything else missing let me know so I can tell him. Thanks guys.
[Modified by UpstateCivic, 11:31 PM 3/1/2003]
pitoracing24
02-13-2008 08:10 PM
B18 CYA
03-24-2006 03:23 PM
