How do you know when its throwing a code (b16A2)
Old Mar 1, 2003 | 09:59 AM
sshaikh01's Avatar
Default How do you know when its throwing a code (b16A2)
I have a 99 si with P2T ecu.
The ecu does not have a light, so how would i know if the car is throwing a code or not?
Also how are you suppose to mount the ecu on the 99-00 civic si
I know these are stupid questions. thats why i'm here.
thanks
Old Mar 1, 2003 | 10:02 AM
Stryker908's Avatar
Default Re: How do you know when its throwing a code (sshaikh01)
thanks
CEL light comes on ... to check it there is a small harnes under the dash on the pass side. Just put a jumper wire in and turn the key "ON" the CEL light will blink the code ... hope this helps
and remember there are no stupid questions just stupid people Like me
Old Mar 1, 2003 | 10:07 AM
sshaikh01's Avatar
Default Re: How do you know when its throwing a code (Stryker908)
thanks
Thanks, so i'll have to look for CEL light, and see if it blinks or not.
Thanks, i needed to make sure that.
Another thing.
Here is my situation.
I have don't have a carpet in my car, (theft) where am i suppose to bolt the ecu down to.
Does anyone have a pic of how the ecu sits on 99-00 civics
thanks
Old Mar 1, 2003 | 10:10 AM
Stryker908's Avatar
I got a 93 HB there is a mount on the pass side under the dash I will take a pic for you when i get home I dont know bout 99-00 si's hope this helps
Old Mar 1, 2003 | 12:04 PM
RacerXI's Avatar
The ecu sits in the passenger kick panel. If you need a pic, i'll shoot you one of my car.
Old Mar 1, 2003 | 09:26 PM
sshaikh01's Avatar
Default Re: How do you know when its throwing a code (RacerXI)
please
Old Mar 1, 2003 | 09:28 PM
sshaikh01's Avatar
I was afaird of this.
I have a CEL.
So, now i need to know which code is it throwing.
What kind of jumper wire would i need, and what does that harness look like which i need to put the wire in.
Old Mar 1, 2003 | 10:56 PM
redline201's Avatar
you can use a paper clip
i just used some wire
Old Mar 2, 2003 | 09:34 AM
sshaikh01's Avatar
Default Re: How do you know when its throwing a code (redline201)
I went under the car can't seem to find the harness.
This is how i have the ecu right now.
here is what's under the pass dash.
Old Mar 2, 2003 | 11:57 AM
Steve Berman's Avatar
heres some info on wiring for my 92 civic. Im sure they share similarities.
https://honda-tech.com/zerothread?id=427156
Old Mar 2, 2003 | 12:06 PM
RaIn's Avatar
Default Re: How do you know when its throwing a code (Steve Berman)
Ok on the last picture there do you see the GREEN plug in the top right, thats what you need, take that cover off, and theres a clip inside that i think it has a brown and black wire into the clip, (if you look really close you can see it in the pic) you want to bend a paper clip in the shape of a U and stick one end in each side of where each wire is going, so its touching metal and shorting it out.
[Modified by RaIn, 9:06 PM 3/2/2003]
Old Mar 2, 2003 | 04:03 PM
Pele's Avatar
Default Re: How do you know when its throwing a code (RaIn)
Yeah. the two wire one. (My 1993 has two connectors in the little green cap. I dunno what the three pin connector does, but the two wire one shows codes... If anyone can tell me what the 3 wire one does, I'd like to hear.)
Anywho. You stick your paperclip or jumper wire in there so that it bridges the two wires of the two wire connector. Then watch the Check Engine light. It'll blink... Long blinks are the first digit. Short blinks are the second digit. All codes are two digit. They repeat at the end.
For example. LONG LONG short <wait a few seconds> LONG LONG LONG short short short short <wait a few seconds> <Start from the begenning again>
Means codes 21 and 34 are present... I just used those as an example, my code book is in my car, so I can't tell you what they are...
Post up what codes you're getting later and I can run out and get it to tell you what's goin on.
Also, After you fix whatever's wrong, the code will stay there... You've gotta disconnect the battery to clear it. You've also gotta lose your radio settings.
Old Mar 2, 2003 | 04:21 PM
sshaikh01's Avatar
Default Re: How do you know when its throwing a code (Pele)
Thanks a lot
Old Mar 2, 2003 | 04:27 PM
SilverCivicDxR's Avatar
This Site Will Tell You How To Do It (With Photo's) And Give You The CEL Codes
http://www.personal.psu.edu/users/m/...ngine_code.htm
Hope This Helps
Old Mar 2, 2003 | 04:37 PM
sshaikh01's Avatar
Default Re: How do you know when its throwing a code (SilverCivicDxR)
Hope This Helps
yep it sure did, i know extacly what to do.
Thanks
duh blacksheep
Dec 13, 2004 07:54 AM
carnifex
Oct 1, 2004 10:28 AM
stockintegra
Mar 27, 2004 02:13 PM
Toda Built
Jul 10, 2003 02:46 AM
