Swap done...........idle problems then stalls
Old Mar 1, 2003 | 02:18 AM
civicrtype's Avatar
Default Swap done...........idle problems then stalls
Sup I did a b18b swap in my 98 EK. I am using and OBD2 LS motor with an OBD1 LS ecu. Here's the problems:
Idle surges from below 500rpm to 2000rpm then if I let go of the gas then the car stalls.
Car does not go about 3k rpms. What could it be??
Help me out need my car running good. I got a CEL but I havent checked out. I will but I was hoping u guys can give me some ideas.
Old Mar 1, 2003 | 02:20 AM
nismonotmugen's Avatar
Default Re: Swap done...........idle problems then stalls (civicrtype)
Did you check the hoses? That was the problem in my Z.
Old Mar 1, 2003 | 08:35 AM
silverEH2's Avatar
Default Re: Swap done...........idle problems then stalls (nismonotmugen)
i would put an obd 2 ecu in, and go from there
Old Mar 1, 2003 | 08:39 AM
deez nuts's Avatar
Default Re: Swap done...........idle problems then stalls (silverEH2)
same thing happen to me.... bogging 1ooo-3000 trouble starting unless you let a little gas in if not it stalls. the problem i had but i got it fixed was my wiring connected to the ecu because if you did the wiring ghetto and cutted wires everywhere it might be the problem.
Old Mar 1, 2003 | 08:47 AM
Malachi's Avatar
make sure all the connections are to the right sensors, there are two that have the same plug. check for vacuum leaks, check wiring and adjust the idle.
Old Mar 1, 2003 | 02:39 PM
civicrtype's Avatar
Default Re: Swap done...........idle problems then stalls (Malachi)
Thanks for the replies fellas gonna look it over and see whats up. I did try the OBD2 ecu and same thing.
fastblacks2k
11
Jan 25, 2010 12:22 PM
fitbmx86
Feb 29, 2008 05:59 AM
s0flyy56
May 23, 2007 06:52 PM
B-SerioUs EGg
Dec 29, 2005 06:49 AM
mnneon
23
Oct 2, 2005 03:53 PM
