Step by step on how to change a Tial WG Spring
Old Mar 1, 2003 | 01:43 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Step by step on how to change a Tial WG Spring
I always get asked this so I figured I would show you how easy it is. I will be changing a .65bar to a .45 bar spring.
1) Remove the 6 4mm allen bolts out. I usually loosen up a bolt making a complete turn, then I move to the next one. This keeps the upper cap of the wastgate from being uneven.
2) One the bolts start to come loose, make sure you keep your hand over the cap from popping off. I was able to do this by hand because it was only a .45 bar spring, but if you use a higher spring rate I suggest using a clamp of some sort to hold it down.
3) Now that the cap is off, remove the old spring.
4). Install new spring.
5) Then just install the cap back on over the spring and bolt it back down.
See how easy that was? Now if someone asks you, you can send them to this simple link.
art
Old Mar 1, 2003 | 01:54 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: Step by step on how to change a Tial WG Spring (Arturbo)
Nice post Art. BTW people, if you cant (or dont) have a clamp, simply have somebody thats near you give you a hand, that spring is pretty tight, and sometimes can be tedious when working with the small allen bolts.. If you do not have some sort of clamp, dont be ashamed to ask a buddy for a hand, its better then loosing an allen bolt...... PS, sorry to bogart your post Art, hehe
Old Mar 1, 2003 | 04:42 AM
rOby's Avatar
Default Re: Step by step on how to change a Tial WG Spring (SIXTYdashONE)
so easy, i not believe.
good info
Old Mar 1, 2003 | 05:21 AM
boostaholic's Avatar
Default Re: Step by step on how to change a Tial WG Spring (rOby)
I am the master at changing wastegate springs, especially while the car is on the dyno and extremely hot! Now that is a pain in the ***! Good thread art, i get asked this all the time too
Edit : a tip if you're changing the wastegate spring with the wastegate out of the car - put the wastegate in a vise to hold down the upper half while you remove the allen head bolts. Makes it alot easier to back out the allen head bolts sometimes especially if you're using a really stiff spring.
[Modified by boostaholic, 8:24 AM 3/1/2003]
Old Mar 1, 2003 | 05:33 AM
SoulSurfer's Avatar
Default Re: Step by step on how to change a Tial WG Spring (boostaholic)
I no get it .
Good write up Art. Things like this may be basic but since I've only been researching turbos for 6 months (with no turbos in the local area) it's very helpful.
Old Mar 1, 2003 | 06:16 AM
Diego Boost's Avatar
Default Re: Step by step on how to change a Tial WG Spring (LSDelSol)
Good post.
Old Mar 1, 2003 | 06:27 AM
DIRep972's Avatar
Smarter than you
good post art i have always wondered how to change a wastegate spring
you should do more of these
Old Mar 1, 2003 | 07:32 AM
B20-T's Avatar
Default Re: Step by step on how to change a Tial WG Spring (DIRep)
hehe that my w/g i order from art
Old Mar 1, 2003 | 07:44 AM
MyWhiteCivic's Avatar
Now I need to find a 1.2 bar spring. Thanks for the information!
Old Mar 1, 2003 | 09:52 AM
swlabhot's Avatar
NIce one. I was wondering this lately.....
Just one question. Are the springs clearly labelled on their poundages? As they look the same its hard to tell.
Old Mar 1, 2003 | 09:53 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Step by step on how to change a Tial WG Spring (MyWhiteCivic)
Like everyone stated, you do need a vise to hold it down when using a high pressure spring. Since this was a small spring I did it on my kitchen table and didnt feel like putting it in the vice because its colder than **** outside!
Old Mar 1, 2003 | 10:25 AM
rOby's Avatar
haha ur gonna freeze artsicles
Old Mar 24, 2003 | 04:06 PM
FredoSP's Avatar
good post .. tell a friend!!
Old Mar 24, 2003 | 04:23 PM
Danger's Avatar
Default Re: Step by step on how to change a Tial WG Spring (FredoSP)
good write-up i just did this yesterday . it was a bitch to push and hold down that spring so i could get the allen bolts back in .
how do you determine the rate of the spring ? by the color ?
Old Mar 24, 2003 | 04:47 PM
1fstcorrado's Avatar
if you get asked that what other type of questions do you get asked...........still have not figured out this toilet paper thing....
Old Mar 24, 2003 | 05:08 PM
Tofurky's Avatar
Default Re: Step by step on how to change a Tial WG Spring (1fstcorrado)
thats funny. i always figured the spring was this little tiny thing.
Old Apr 13, 2003 | 04:19 PM
InTeGrA B18b1's Avatar
nj with the steps but there still will be some people asking you about how to do it ahha
Old Apr 13, 2003 | 05:58 PM
Doodoo's Avatar
So Art, you just changed to a lower spring eh? Anybody got dibs on the .65 spring? I could have traded you too....a well.
Old Apr 13, 2003 | 06:52 PM
TurbothisLS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">Like everyone stated, you do need a vise to hold it down when using a high pressure spring. Since this was a small spring I did it on my kitchen table and didnt feel like putting it in the vice because its colder than **** outside! </TD></TR></TABLE>
in TX???
Old Apr 13, 2003 | 07:08 PM
T3's Avatar
T3
Default Re: Step by step on how to change a Tial WG Spring (TurbothisLS)
Lmao..Nice I guess...
Art, will the tial spring fit in an Audi ex wastegate?I needa get rid of this 1 bar pos.
Old Apr 13, 2003 | 09:48 PM
SiR Kid's Avatar
New User
Default Re: Step by step on how to change a Tial WG Spring (T3)
I need a better wastegate spring soon... Does Ben sell thsoe by themselves?
Any ideas on retail $$$?
Old Apr 14, 2003 | 03:45 AM
Snafu-Si's Avatar
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
Default Re: Step by step on how to change a Tial WG Spring (SiR Kid)
I only have a .3 bar spring. Is that too small?
I mean, I'm only running 5psi, and I havea greddy profec B boost controller if I want to boost up.
My wastegate braps kind of loud though. I kinda like it
Even if I want to boost up, I would only plan on running 7 on hi boost, and 5 on the street.
Would I really see any benifit of going with a different spring? What kind of benifits if ANY would I see?
Old Apr 14, 2003 | 03:56 AM
BROOD's Avatar
Am I incorrect on my 35mm spring colors???
I thought a red was a 0.45 spring and a yellow was a 0.30 spring.
I know for a fact that green is the 0.65 spring.
I've changed 0.65 springs many times by holding the cap by hand. It is easier with the WG removed and set on a table, with one hand holding down the cap and other hand working the allen wrench.
**I have always used Tial 35mm WGates.**
Modified by SLPR at 6:04 AM 4/14/2003
Old Apr 14, 2003 | 04:52 AM
T3's Avatar
T3
Default Re: Step by step on how to change a Tial WG Spring (SLPR)
Seems like im the only one running an ex Audi
Modified by T3 at 4:08 PM 5/1/2003
Old May 1, 2003 | 12:04 PM
Slick GS-R's Avatar
so is that .65 spring for sale?
i want it!
