B16a1 swap into 90 Civic SI HB
Old Mar 1, 2003 | 12:10 AM
red_honda_racer's Avatar
Default B16a1 swap into 90 Civic SI HB
I have a ZC motor right now that I put in and I'm swapping in a b16a1, I know I can get a mount kit from Hasport.com and a shifter linkage. But my worry is when it comes down to the wiring, If I buy the wire harness, is that all I need for the wiring? Or is there more wiring stuff to buy? The motor is coming with the ecu too, so I don't have to buy one, and is there anything else I need to get for this swap or any good tips you guys could give me?
Old Mar 1, 2003 | 02:26 AM
inFamousOneSix's Avatar
Default Re: B16a1 swap into 90 Civic SI HB (red_honda_racer)
you don't need to buy a wire harness. You re-use your stock wire harness. everything plugs up. You only have to add four wires: vtec solenoid, oil pressure switch, secondary o2 sensor, and knock sensor. Go here for details: http://b16a.honda-perf.org/theswap.html
Simple stuff if you know how to crimp wires together.
Old Mar 1, 2003 | 06:42 AM
projecthybrid04's Avatar
Go to hasport.com and buy there subharness for 75 bucks.
Old Mar 1, 2003 | 08:34 AM
Rywire's Avatar
Default Re: B16a1 swap into 90 Civic SI HB (projecthybrid04)
buy the sub-harness, and then you wiring is done, its that easy. Ryan
ps, you can visit my site for swap help. Ryan
Old Mar 1, 2003 | 09:39 AM
Default Re: B16a1 swap into 90 Civic SI HB (droppedcrxsi)
Cool guys, Thanx. I figured if I bought the subharness I would be fine, but I really like to double check these things before I get to far ahead. Thanx
Old Mar 12, 2003 | 11:26 PM
What about Axles, and some dent I was told to make for Alternator clearance?
[Modified by red_honda_racer, 8:26 AM 3/13/2003]
Old Mar 12, 2003 | 11:43 PM
Malgerus's Avatar
Axles= 90-93 Integra, and depending on the mount kit and alternator belt, yuo may need to make a dent. I didn't. I simply used a short alt belt and my mounts mount the engine fairly far forward, it seems. They're from http://www.spituning.com
Old Mar 13, 2003 | 08:39 PM
Rywire's Avatar
90-93 teg axles only work with a teg int shaft(xsi b16a). If your b16a is from a ef, you need custom made ones. Go to hasport.com for directions.
Use a shorter alternator belt, but I suggest making the dent as well. I have both the dent, and the shortet belt. I have about a half inch clearence. which is near perfect (Iguess). I have a hasport mount kit. Ryan
shitvic01
Honda Civic (2001 - 2005)
Dec 28, 2006 06:40 PM
labatia
Jun 24, 2004 05:27 PM
infinatenexus
Nov 4, 2003 11:07 AM
Charlie Moua
11
Apr 18, 2002 05:00 PM
KoRE
Feb 15, 2002 08:01 AM
