o2 simulator that works with the heater circuitry
i did a search and could not find what i was looking for. I'm looking to eliminate the secondary o2 sensor totally. Are there any o2 simulators out there that can actually simulate the heater circuit of the 4 wire o2 sensors? all the o2 simulators that i can find requires the sensor to be hooked up to the exhaust.
which ones have u been looking at??? cause i also am looking for a product like that but on that suports 5 wire 02 .Am looking at the ECG Electronics Test Pipe 02 Simulator ,from importparts.Not sure if u still need a 02 for that 1???
HAy ZIP,
MY D15z1 only has 1 o2 sensor and has two heater circuts inside thats why its 5 wire i think??ANyway will it work on my engine ??I dont mind putting a few resistors on just as long as my car is not throwing a cel.
p.s no i wont just take the globe out ,cause my car almost blows flames its that rich.
The O2SIM is only for OBDII applications that eliminate the secondary O2 sensor because of a test-pipe. The O2SIM doesn't replace the primary O2 sensor.
1993eghatch
Sep 24, 2010 05:52 PM
