Fuel Line Installation
Risky Business
Posting a question for a another member of a different board...NOT my question so dont flame
"Ok... so I cracked my fuel line... the main line running from the tank to the bottom of the fuel pump...I got a replacement from Honda. I ripped out the old one by cutting it... HOW THE HELL??? do I put in the new one? I tried to feed it thourgh but it won't go... do I have to remove a lower part of the suspension?? to lay the line..... I NEED HELP my car is stranded at my friends garage... or should I tow it to HONDA and let them do it for 100.00 dollars??"
[Modified by BauleyCivic, 5:49 AM 3/1/2003]
if i remember right he will have to drop the front subframe, because the line runs behind it, other then that it should be fairly easy
when i crimped my line trying to make it fit to a teg filter, i just cut out the bad pieces and put in a new piece, just in that area, i took one look at the line running behind the subframe and decided it wasnt worth it to replace the whole line. but i guess that really doesn't help him now does it
ah well next time i guess
Eran
24
Oct 25, 2008 12:48 AM
hybridmoments
Feb 15, 2007 07:55 AM
