b16 running like garbage
Old Feb 28, 2003 | 07:05 PM
type Gendy's Avatar
Default b16 running like garbage
My car just started running poorly tonight. I was pulling out of a road, it was a lil cold, not fully warmed up yet, and it just started dying, like it was gonna stall out. I very slowy reached 50 mph then it began to run smoother. I drove for an hour on the highway today if that has anything to do with it, but it ran like a top.
The only thing i can really compare it to is driving a snowmobile with one of hte plug wires off......if anybody can relate to that, which i doubt.
I filled it up with gas, put dry gas in it, drove it around a bit, and it almost seems to be worst. I checked all my grounds and they seem to be fine. What could cause my car to all of sudden be acting like this.
Thanks for any info
Old Feb 28, 2003 | 07:39 PM
d-wreck's Avatar
Default Re: b16 running like garbage (sick hatchem)
sounds like a ignition coil to me man. ..
symptoms of a bad coil would be irradic acceleration, decreased gas mileage, over suckassness
im fairly sure this is your problem, but if you dont want to replace parts on a guess take it into a shop and check for sure, or borrow someones coil and see if that fixes it.
one of the funny things is that aftermarker ignition, with external coil is almost the same price as a new coil, if you just want to get the 6A msd. . .
anyway hope you get the problem fixed up man
derek
Old Feb 28, 2003 | 09:03 PM
ThatRicerDaniel's Avatar
thats easy .. fouled spark plugs.
Old Feb 28, 2003 | 09:54 PM
RCautoworks's Avatar
Default Re: b16 running like garbage (NitrousDreamz)
What about the fuel filter ? Did it just bog down that one time ? Maybe somthing got caught in it. Whens the last time you changed your fuel filter ?
Old Mar 1, 2003 | 05:27 AM
type Gendy's Avatar
Default Re: b16 running like garbage (90blackcrx)
NO the problem seems to be getting worse, was happening all last night.... Gonna go drive it to town this morning, see if the dry gas made any difference, otherwise idk, gotta drive an hour to work today, dont wanna get stranded or mess anything up on the motor bad.
Anybody else?
Old Mar 3, 2003 | 09:35 AM
type Gendy's Avatar
The number 1 plug was wet, looked like it had a drop of water? on it, never seen a spark plug that wet before, dried it off, put it back in , and ran fine.
Old Mar 3, 2003 | 10:02 AM
SiR831's Avatar
any codes?
DEEGORILLA06
13
Aug 19, 2009 02:14 PM
EJ1chevelle
Sep 19, 2007 12:34 AM
93c1sol
Aug 28, 2006 02:28 PM
buzlink
Dec 29, 2005 08:45 PM
trooper0641
22
Jan 3, 2004 09:14 PM
