GaUgE ClUdTrR!!!!
Old Feb 28, 2003 | 02:39 PM
boydoubt's Avatar
Default GaUgE ClUdTrR!!!!
hello,
ok well i have a 94 civic dx. which does not have a tach. i just ordered an EX gauge cluster from ebay so basically i was wondering if i can just take my old dx cluster out and put the new ex cluster in and just be able to plug it all in and the tach will work.
i have heard that every civic comes with the tach wire all ready and all you have to do is plug it in. i have also heard that the non-tach civics do not come with this wire and you have to install it your self.
which one is true?
thanks
Old Feb 28, 2003 | 02:42 PM
Spade's Avatar
Default Re: GaUgE ClUdTrR!!!! (boydoubt)
Plug and Play.
BTW, loose the stupid caps, no caps writing.
Old Feb 28, 2003 | 02:44 PM
boydoubt's Avatar
Default Re: GaUgE ClUdTrR!!!! (Spade)
sorry bout the caps. but i guess iam stupid does "plug and play" mean that the i just plug it in and go and i dont have to install a wire my self?. sorry if i sound stupid but iam a newb at this so.....
Old Feb 28, 2003 | 02:45 PM
Spade's Avatar
Yer not stupid, you just don't know the term.
Yes, Plug and play means....plug it in and it works, no changes needed from you.
Old Feb 28, 2003 | 02:48 PM
Malachi's Avatar
remember theres a stupid screw behind the hazard button. just take the button off then you will be able to pull of the plastic around it. there will be a screw in there and 2 more under the topside of the plastic near the guages. be carefull of the plastic clips. gl
Old Feb 28, 2003 | 02:51 PM
acydphryck's Avatar
hello,
which one is true?
thanks
actually, it would be more helpful for you if you ask us questions BEFORE you buy a product so you save time and $$$ if the product doesn't work with your application...know what i mean? some people here might flame just for that you know? the cluster should work with no modifications or wire cutting...
boydoubt's Avatar
Default Re: GaUgE ClUdTrR!!!! (Malachi)
o wow thats cool thanks alot for all the info guys it really helped.. thanks again
Old Feb 28, 2003 | 02:53 PM
Spade's Avatar
Old Feb 28, 2003 | 02:56 PM
Malachi's Avatar
np, if you come across an extra one of those plastic trims let me know
DISCONNECT your negative battery cable too, i dont do it for stereo stuff and a few other things, but you will have to mess with your srs plug so make sure you do.
Old Feb 28, 2003 | 02:58 PM
Spade's Avatar
I broke my clips too but, just left it sitting in the cluster bay....
Old Feb 28, 2003 | 03:08 PM
Evs-One's Avatar
Solbros Owns Me
haha, I broke one of the bottom clips on mine too.
Now I have a little gap right below the tach/speedo between the trim and the dash...and GOSH it's annoying.
Gonna use some 3M double sided tape
edit- Also, before you fasten the cluster back in, plug it in, turn on your lights, and make sure EVERHTING works. At this point, you can swap out bulbs from your old cluster as needed, rather than taking everything back out again. Another mistake I made...lol
[Modified by Emerica, 4:10 PM 2/28/2003]
Old Feb 28, 2003 | 09:46 PM
boydoubt's Avatar
Default Re: GaUgE ClUdTrR!!!! (Emerica)
i will make sure to do that all thanks again for all the info guys.
Old Feb 28, 2003 | 10:26 PM
JDMvtecDRAGSTA's Avatar
Plug and Play.
LU
Nov 20, 2005 08:11 PM
opiumdaze
Aug 10, 2005 01:25 PM
sicx
Oct 6, 2004 10:37 AM
hipochevys
Aug 1, 2004 05:35 PM
kent
Mar 2, 2003 06:23 PM
