Radiator fan not coming on after swap
Old Feb 28, 2003 | 12:37 PM
Ehron's Avatar
Default Radiator fan not coming on after swap
Hey guys. Now that the car runs the radiator fan is not coming on. I switched to a bigger Koyo radiator when I did the swap. 2000 b16a2 into a 97 dx. I used the 2000 si ecu and wiring harness. Stock fan. Rewired dash to use 2000 ecu. Exhaust temps climbed to around 221 before I turned the car off.
Any ideas??
I double posted this because I get very few responses in Hybrid...
Thanks.
Old Feb 28, 2003 | 12:43 PM
ongking's Avatar
Default Re: Radiator fan not coming on after swap (Ehron)
I had same problem when they installed my b16a2 (2000 si) to my 1997 civic. AEBS, fro San Diego, fixed it I don't know how though.. Try to give them a call..
Old Feb 28, 2003 | 12:45 PM
Ehron's Avatar
Default Re: Radiator fan not coming on after swap (ongking)
Think they would fly to Georgia to fix it for me?
Old Feb 28, 2003 | 12:52 PM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
Sure the the theermoswitch is good???
Do you know how hot that car gets....I think the fans are supposed to cut on @ about 210-220.
dogpile5's Avatar
25 Year Member
depends on which gen motor you put in and whether you reconnected the fan relay temp switch. old gen motors the temp switch it behind the block next to the oil filter. newer gen motors have the switch on the thermostat houseing. first jump the fan relay plug on the engine wiring harness with the key in acc and see if the fan comes on. if it does, you likely have a bad sensor.
Old Feb 28, 2003 | 12:53 PM
Evs-One's Avatar
Solbros Owns Me
it doesn't matter how hot you're exhaust gasses get.
Check a few things...
-is the cooling system bled?
-is the thermostat opening up?
-does the fan turn on when directly wired to the battery?
The fan will ONLY turn on when the water inside of the radiator reaches a certain temp. With this said, it means that if the fan and relay are both good, then you're water isn't flowing to the raciator. It could be due to a few different variables including those listed above.
Old Mar 4, 2003 | 04:59 PM
Ehron's Avatar
I did not mean to say exhaust temps. I was pissed off (could anything else go friggin wrong with my swap ), and I meant to say the temp on the scan tool climbed to 241 f.
The thermostat opens, the radiator has no flow impediments, and I am bleeding the system right now. Hopefully good news for the morning.
Old Mar 4, 2003 | 05:01 PM
DragII's Avatar
25 Year Member
after my swap, I installed a del sol dual core, and I thought the fan wasn't coming on too, turns out, the car was just running that much cooler, I had to beat it up before the fan needed to come on.
Old Mar 4, 2003 | 05:06 PM
Ehron's Avatar
Default Re: Radiator fan not coming on after swap (DragII)
Well the scan tool said 243 F, and I smelled burnt coolant so I am pretty sure I have a problem . I swapped in a Koyo while doing my swap as well. Then my car over heated while going 55 mph on a 50 degree day with a slight mist in the air. Drop it in start it my ****...
chellerfl
Jul 13, 2016 07:43 AM
KSavaiki224
10
Jun 16, 2015 10:33 AM
dman81
May 28, 2014 03:20 AM
philobeddoe2
Honda CR-V & Element
May 26, 2014 04:56 AM
Ehron
Mar 2, 2003 04:00 PM
