F-ing Ridiculous code 4
Old Feb 28, 2003 | 09:04 AM
xci_ed6's Avatar
Default F-ing Ridiculous code 4
Okay i did a MPFI swap, it resulted in a code 4 (cyl posistion sensor) I have now rerun the wires, tried all combinations (blu/grn-C1, blu/grn-C2), soldered in new connectors, and even broke down and bought a rebuilt distributor ($200 :mad I now have no money and a car that still does not run. My only idea left is the ECU but I swapped in a friends working ECU and it gave a code 4 too.
WTF is wrong!!!!!!!!!!!!!!!!!!!!
-Dustin
Old Feb 28, 2003 | 09:25 AM
EF_LSVtec's Avatar
Default Re: F-ing Ridiculous code 4 (Autocratic_1st_Gen)
check the plugs in your distributor and make sure that all the pins are pushed in all the way. That's what happened to me recently... replaced ecu, distributor still getting code 4. checked the distributor plugs, cleaned em and made sure they're making good contact...solved the problem.
Old Feb 28, 2003 | 10:18 AM
xci_ed6's Avatar
Default Re: F-ing Ridiculous code 4 (EF_LSVtec)
I thought that might be a prob so I pulled them out of the plug and did a *light* tack with solder directly to the wire, no fix. Or do you mean inside the housing?
-Dustin
Old Feb 28, 2003 | 10:55 AM
EF_LSVtec's Avatar
what it is, is loose connection. I'd trace from the distributor all the way to your ecu and make sure that you have a good line. I found out that if there's a bad connection, distributor heats up so much that sensors fail resulting in codes...in this case code 4.
Old Feb 28, 2003 | 12:23 PM
xci_ed6's Avatar
This is imediatly@ startup. What do you mean, like all the wires? I just ran new wires to the cyl pos sensor again. completely outside the car, all new ECU pins, and soldered to the dist. pins. Does not work. I even had the bat disconected for 10 min to make sure it got reset
-Dustin
Old Feb 28, 2003 | 12:41 PM
EF_LSVtec's Avatar
check this one out...it's not as clear but it helped me with my woes.
http://coreyonline.tripod.com/part6.html
Old Feb 28, 2003 | 03:01 PM
zCivic's Avatar
For starters code 4 has nothing to do with the blue/green blue/yellow wires that is Cylinder Position sensor code 9. Code 4 is Crank postition sensor check at your ECU between pins B10 and B12 and see if the resistance is between 350 and 550 ohms. At the Diz one wire is orange and the other is white with red tape it usually. Test the resistance between them also should be 350-550 ohms. you have B10 connected where orange wire I think use to be C1 and B12 to the white wire I think was C2. If the resistance checks out try swaping pins B10 and B12 you may have them revesed if the sensor is picking up backwards (even though instructions say it doesn't matter) will throw a CEL now get out and test it I/M me if still have problems.
cornfed
Engine Management and Tuning
Jan 27, 2012 02:49 AM
b16a1eg6
Jan 17, 2007 03:32 PM
turbob18si
Dec 3, 2006 04:02 PM
zccr-xsi
Jun 5, 2005 03:49 PM
Spade
Jul 30, 2002 02:05 PM
