B16a2 camshaft profiles.
Old Feb 28, 2003 | 03:22 AM
simonc's Avatar
Default B16a2 camshaft profiles.
Does anyone know what the cam profiles, including the vtec lobe, on a B16a2 are?
Old Feb 28, 2003 | 03:25 AM
thinkbrianthink's Avatar
Default Re: B16a2 camshaft profiles. (simonc)
Honda OEM and Aftermarket B-Series VTEC Cam Shaft
Chart:
Cams Measured at 1mm of lift:
Integra Type-R(Through 1999 Spec)
Int-240 dur. / 11.5mm lift
Exh-235 dur. / 10.5mm lift
Civic Type-R And Integra Type-R(Integra Type R 2000/01
Spec)
Int-243 dur. / 11.5mm lift
Skunk2 Stage 1
Int-252 dur. / 11.5mm lift
Exh-249 dur. / 10.8mm lift
JUN Type 1
Int-265 dur. / 10.9mm lift
Exh-268 dur. / 10.0mm lift
Spoon Sports
Int-256 dur. / 11.5mm lift
Exh-245 dur. / 11.1mm lift
JUN Type 2
Int-267 dur. / 12.0mm lift
Exh-265 dur. / 10.9mm lift
Skunk2 Stage 2
Int-266 dur. / 12.3mm lift
Exh-262 dur. / 11.8mm lift
JUN Type 3
Int-265 dur. / 12.0mm lift
Exh-265 dur. / 11.5mm lift
Skunk2 Stage 3
Int-270 dur. / 12.8mm lift
Exh-279 dur. / 11.8mm lift
__________________________________________________ ____
Cams Measured with 0mm of lift:
Civic Si(1999 Spec)
Int-265 dur. / 10.5mm lift
Exh-267 dur. / 9.6mm lift
Integra GS-R
Int-274 dur. / 10.7mm lift
Exh-276 dur. / 9.6mm lift
Crower 400
Int-279 dur. / 10.7mm lift
Exh-280 dur. / 9.6mm lift
Spec)
Int-278 dur. / 11.5mm lift
Exh-280 dur. / 10.5mm lift
Crower 401(NA Version)
Int-282 dur. / 11.3mm lift
Exh-277 dur. / 10.5mm lift
Crower 401-T(Forced Induction Version)
Int-280 dur. / 11.8mm lift
Exh-276 dur. / 11.3mm lift
Toda Spec A
Int-290 dur. / 11.6mm lift
Exh-280 dur. / 11.2mm lift
Crower 402(Both Regular 402 and 402-A, 402-A is milder
off VTEC)
Int-297 dur. / 11.8mm lift
Exh-287 dur. / 11.8mm lift
Toda Spec B
Int-295 dur. / 12.0mm lift
Exh-285 dur. / 12.0mm lift
Crower 403
Exh-293 dur. / 11.8mm lift
Toda Spec C
Int-295 dur. / 12.5mm lift
Exh-295 dur. / 12.5mm lift
kingofbattle909
Oct 2, 2010 01:10 AM
fracas
70
Feb 28, 2010 05:17 PM
arexniba
Nov 25, 2006 01:05 PM
-=MUGEN=-
Oct 14, 2005 11:41 AM
gefiltefish
May 10, 2002 01:15 PM
