Timing issues
Old Feb 27, 2003 | 09:54 PM
Wicked Sol's Avatar
New User
Default Timing issues
I just got done doing an ls/vtec swap and for some reason I can't seem to get the timing right. The timing gear is lined up with the notch on the oil pump and the 2 lines on the cam gears I lined up the center of the tooth with the mark on it with the edge of the head. I'm missing the upper inner timing cover so I used the head instead thinking they are the same.
When I check the timing with the connecter jumped I have to fully advance the timing and the first timing mark on the crank pulley doesn't line up with the mark on the cover. Its close but still idles like its camed and I'm only pullen 15" of vaccum. Any ideas?
Old Feb 28, 2003 | 10:02 AM
Wicked Sol's Avatar
New User
Default Re: Timing issues (Wicked Sol)
anyone one?
Old Feb 28, 2003 | 12:19 PM
XDEep's Avatar
arent you supposed to use a different belt when you put the b16 head on? if not id triple check your timing belt install. retension it etc
Old Feb 28, 2003 | 02:43 PM
Wicked Sol's Avatar
New User
Default Re: Timing issues (XDEep)
I am using a gsr belt with a gsr head and water pump.
Old Feb 28, 2003 | 03:58 PM
biggdogg's Avatar
pull the #1 spark plug out and get a 3/8 '' long extension and drop it in the #1 piston hole. watch it go all the way up and top out . you are at tdc. if that don`t work check your crank angle sensor wire is crossed up with another wire on the distributor . mine was swapped with the tdc wire and it ran close to that same way
[Modified by biggdogg, 7:59 PM 2/28/2003]
swizz977
Apr 19, 2015 09:04 AM
Justephen Sae
Feb 1, 2015 08:20 AM
miguey310
Aug 21, 2010 09:20 AM
Salsa
Feb 28, 2009 11:31 AM
Fresh'86
Oct 1, 2008 04:46 AM
