weird noises . .
Old Feb 27, 2003 | 07:10 PM
makaveli284's Avatar
Default weird noises . .
Hey guyz, im kinda worried because everytime i make a sharp or even a slight left turn, i hear squeaking noises coming from the drivers side rear. This also occurs if i go over bumps, but the noise only comes from the driverside rear. WHAT COULD IT BE.
aaaaaaaah one more thing, ma engine makes this funny bubbling noise if i tap the accelerator, is there sumthin wrong with my engine?
Old Feb 27, 2003 | 07:27 PM
Default Re: weird noises . . (makaveli284)
come on . . . anyone . . . cud it be my shocks ? springs ?
Old Feb 27, 2003 | 08:07 PM
romeo619romeo's Avatar
bubble sound? if it doesnt drive correctly check your cap might be wet... or your plugs....the sound in the rear might not be in the rear if you droped your car might be your brake shield pressing against the rotor when you make a turn
Old Feb 27, 2003 | 09:29 PM
Default Re: weird noises . . (romeo619romeo)
i dont know, the car isnt lowered at all yet. i am almost 100% sure its coming from driverside rear . . . i would check for myself, but its snowing outside . . AGAIN . . could it be messed up shocks or springs?
Old Feb 27, 2003 | 10:35 PM
Spartanic's Avatar
hmmmm......could be a worn wheel bearing on the brake caliper due to agressive turning or could even be a bad suspension bushing. Try this, remove front tires, jack the car up and let it sit on jackstands, make sure its sturdy, then get under the car and start wiggling and jiggling the suspension parts back and forth, there shouldn't be any movement and if there is then that means something is loose, could be a worn out bushing causing your suspension to cause excessive movement. Oh yeah, when jiggling the suspension parts you must do it with some force not just a tiny tug, remember that suspension parts move a whole bunch so you jiggiling it wont hurt it.
Old Feb 27, 2003 | 10:46 PM
JpiZz0's Avatar
Default Re: weird noises . . (Spartanic)
either that or the bushing in the rear is on its way out(squeking) as far as bubbling?radiator pressure too high might wanna check on that especially if the temp outside is pretty high.
jp
Old Feb 27, 2003 | 10:50 PM
Spartanic's Avatar
I remeber one time I heard a bubbly noise comin from my engine bay as well and it turned out to be the coolant boiling uncontrollably in the coolant reservoir. As it turned out my water pump was defective causing the raise in engine temp which then boiled the coolant.
Old Feb 27, 2003 | 11:22 PM
well i dont think the bubbling noise is anything that serious(or so i hope) b/c the engine temp hasnt been acting up at all. Im hoping its just like the coolant or something. but man ima b UPSET if the squeaking is comin from some expensive suspension part, cuz i JUST bought the car a month ago
AznInvasion
Jul 24, 2007 04:49 PM
Shushiplease
Mar 9, 2007 01:47 PM
govtec
Apr 4, 2005 02:49 AM
OEMedUP
52
Apr 21, 2004 10:41 AM
deviant1
Dec 3, 2003 05:41 PM
