car wont start, help please
i checked all the obvious grounds ,plugs etc . i have spark and i have fuel and there is a little more than a 1/2 a tank of gas . Any ideas please help
Okay have you did a tuneup or messed with any timing what so ever?...
are you throwing any codes?
whats your vacuum while cranking?
basically.....if your getting spark and fuel..and your battery IS good for sure.....Id say a bad ignition module....see your primary side of the igniton system is fine if your getting spark obvouisly its going through your battery and through the starter then to your coil....but when it hits your module the module could be shot and merely act as a resister to slow current flow but your plugs and wires are still firing on the secondary side....
the motor was just built brand new plugs and wires were installed im gonna change cap and rotor today .( If that was the problem wouldnt i have no spark? ) Timing belt was just done , maybee it could a jumped a tooth . Also u asked about vacuum, i have an extremely bad vacuum leak and i desperateley need a brake booster (could that affect the car starting?) What do u guys think?
TheTealHatch
13
Oct 15, 2008 04:02 AM
rewerbcrx
24
Mar 11, 2006 06:40 AM
