Tire pressure ?
just curious what you guys reccomend for 205 45 16's?? It says 44psi max and pumped mine to 40psi..seems to make my ride stiff but steers easier than when it as at 35psi....i inflaed to these specs on a cold tire (not driven on for and 16hours)wha do you guys run?
Well, I have 205/50/15's that says the max is 51 P.S.I. So I run 45 in it constantly, and add or take out air when the temp changes. You don't want to run very much less than the tire recommends, due to the fact that it will cause uneven wear on the tire. In your case, I think it's a smart idea to run 40 P.S.I. like you have been doing. And having the tire properly inflated will make it easier to steer and make the ride stiffer, that's normal.
Where in the world did you guys come up with those pressures? Are you just guessing? Run the tires at 32 cold, maybe have the front 1 or 2 psi higher than the rear. Tires can be put on many different vehicles (most of which weigh alot more than our vehicles), thus why they have such high pressure thresholds. Just because the max pressure is at 45 doesn't mean you should be running it. The only time you should put pressures that high (and usually not even that high!) is either at the auto-x or a road course.
agreed, 32 is all you need... If you are running 45psi cold and you max psi is 50 what do you think will happen when you drive hard and the pressure builds up??
Wanna here a true story... When I was working at the garage we had a guy with an accord come in and his tires where bubbling and all... He had about 120psi (for real) in his stock tire size... He litterally broke the belt and the tires stared to melt away...
I never put more than 30 psi in mine...
Run lower pressure in the rear tires...reduces oversteer...
yeah some of you guys are saying things i have never heard?
well i have 15"s on my car. thats 195/50/15 and the max is 45. but i run it at 35 psi. some times drop to 32. that seems to work great for my car. and its a little hotter here in hawaii. but still i would say around 35 would be your best bet.
when i go to the track, i run about 50 in the rear and 25 in front. thats drag. auto X is about 32-35 kinda mess aroudn with it as i go.
I'm sorry...typo..
Lower pressure in the rear tires INCREASES oversteer, reduces understeer...
Manufactures design FWD cars to "push" because it is safer for the average driver...less understeer will let your rear end come out early in the turn, allowing the car to point towards the inside of the turn, decreasing the turn radius...
Of course the ideal handling car is "neutral" so find a balance between over and understeer...
[Modified by Kato7997, 1:50 AM 3/1/2003]
I'm sorry...typo..
square_1
12
Mar 24, 2011 01:25 PM
FalkenSiR
Aug 12, 2004 09:17 PM
adrian1281
Jun 28, 2003 08:39 AM
